Old 05-25-2015, 01:21 AM   #1
FrankenCub
FrankenCub's Avatar
Question Break in question, anyone awake ?
I will be installing a new GM crate engine this week and they don't say anything specifically as for cam break in. This is the document they have available to download at Pace
Start-up and Break-in Procedures:
1. After installing the engine, ensure the crankcase has been filled with 10w30 motor oil (non-synthetic) to
the recommended oil fill level on the dipstick. Also check and fill as required any other necessary
fluids such as coolant, power steering fluid, etc.
2. The engine should be primed with oil prior to starting. Follow the instructions enclosed with the tool. To
prime the engine, first remove the distributor to allow access to the oil pump drive shaft. Note the
position of the distributor before removal. Install the oil priming tool. Using a 1/2" dill motor, rotate the
engine oil priming tool clockwise for three minutes. While you are priming the engine, have someone
else rotate the crankshaft clockwise to supply oil throughout the engine and to all the bearing
surfaces before the engine is initially started. This is the sure way to get oil to the bearings before you
start the engine for the first time. Also, prime the engine if it sits for extended periods of time. Reinstall
the distributor in the same orientation as it was removed. After the engine has been installed in the
vehicle, recheck the oil level and add oil as required. It is also good practice to always recheck the
ignition timing after removal and reinstallation of the distributor. See step 4 or engine specifications
for the proper timing information.
3. Safety first. If the vehicle is on the ground, be sure the emergency brake is set, the wheels are chocked
and the car cannot fall into gear. Verify everything is installed properly and nothing was missed.
4. Set initial spark timing at 10o before top dead center (BTDC) at 650 rpm with the vacuum advance line
to the distributor disconnected and plugged. This setting will produce 32o of total advance at wide-
open throttle (WOT). The HEI vacuum advance canister should remain disconnected. This engine is
designed to operate using only the internal centrifugal advance to achieve the correct timing curve.
Rotate the distributor counterclockwise to advance the timing. Rotate the distributor clockwise to
retard the timing.
5. When possible, you should always allow the engine to warm up prior to driving. It is a good practice to
allow the oil sump and water temperature to reach 180°F before towing heavy loads or performing
hard acceleration runs.
6. Once the engine is warm, set the total advance timing to 32° at 3000 RPM.
7. The engine should be driven at varying loads and conditions for the first 30 miles or one hour without
wide open throttle (WOT) or sustained high RPM accelerations.
8. Run five or six medium throttle (50%) accelerations to about 3000 RPM and back to idle (0% throttle) in
gear.
9. Run two or three hard throttle (WOT 100%) accelerations to about 3000 RPM and back to idle (0%
throttle) in gear.
10. Change the oil and filter. Replace with 10w30 motor oil (non synthetic) and a PF454 or PF1218 AC
Delco oil filter. Inspect the oil and the oil filter for any foreign particles to ensure that the engine is
functioning properly.
11. Drive the next 500 miles under normal conditions or 12 to 15 engine hours. Do not run the engine at
its maximum rated engine speed. Also, do not expose the engine to extended periods of high load.
12. Change the oil and filter. Again, inspect the oil and oil filter for any foreign particles to ensure that the
engine is functioning properly.
13. Do not use synthetic oil for break-in. It would be suitable to use synthetic motor oil after the second
recommended oil change and mileage accumulation. In colder regions, a lower viscosity oil may be
required for better flow characteristics.
Nothing about 2000 RPMs for 20 minutes. So, are the new GM engines ok to not go through the usual cam break in ?
FrankenCub is offline   Reply With Quote
Old 05-25-2015, 01:46 AM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Break in question, anyone awake ?
Typically not as important if the engine has a roller cam but I would absolutely check with the manufacture of the camshaft before I took any advise from anyone. The best engine builder would check with the cam manufacture before going forward if not absolutely sure.
If you do not know the manufacture of the camshaft, contact Pace and ask them. I would not take any chances on this.
Hope this helps,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 05-25-2015, 01:54 AM   #3
FrankenCub
FrankenCub's Avatar
That's why I was kinda wondering. This is a new GM engine with warranty from GM, not a refurbished engine. Does GM outsource their cams ?
Old 05-25-2015, 02:01 AM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Prior to the start of roller cams (1987?), the answer is no. They were all GM cams with GM part numbers. As far as what comes in new crate engines, I could not say with 100% certainty. It may very well have a GM part number.
Just be safe and make sure before hand.
Old 05-25-2015, 02:07 AM   #5
FrankenCub
FrankenCub's Avatar
Ok, I'll go through the normal cam breakin procedure for flat tappet cams just to be sure. I certainly don't want problems down the road. Just thought I would question the procedure they offered.
Old 05-25-2015, 02:37 AM   #6
FrankenCub
FrankenCub's Avatar
Thanks TBONE
Old 05-25-2015, 03:47 AM   #7
leftybass209
leftybass209's Avatar
It does make good sense to just do a break-in. It doesn't hurt anything to do it, but can hurt a lot not to. Some may say you don't need to, I think we went through that a year or two ago. In the end if you wipe a cam lobe, they'll move on to another thread to impart poor advice and you'll be left with a bunch of work and less money in your wallet.
This isn't in reference to you or your advice either, tbone!
leftybass209 is offline   Reply With Quote
