Old 05-25-2015, 11:52 AM   #1
bestchevyfan
Question -cab mounts ??????
Who sells the best rubber cab mounts ? Thanks,buddy
bestchevyfan is offline   Reply With Quote
Old 05-25-2015, 07:37 PM   #2
bestchevyfan
Re: Question -cab mounts ??????
Anyone know ?
Old 05-25-2015, 07:40 PM   #3
FirstOwner69
FirstOwner69's Avatar
I bought the rubber mounts for my 3/4 ton from LMC. I'm normally not a fan of LMC, but they seemed to be one of the few sources of mounts just like the original 3/4 ton mounts and they worked out great.
FirstOwner69 is offline   Reply With Quote
Old 05-25-2015, 07:47 PM   #4
amashal
amashal's Avatar
X2 for LMC. I bought a complete kit for my blazer. No complaints at all.
amashal is offline   Reply With Quote
Old 05-25-2015, 07:52 PM   #5
kenn
Hello
How about that, I just crawled out from under my truck after finding my left rear mount ripped apart.
This site is the best.
K.E.N.
kenn is offline   Reply With Quote
Old 05-25-2015, 08:38 PM   #6
In The Ten Ring
I bought mine from Wes at Classic Heartbeat. It worked fine although pricey. I had to turn the rear bolts on the grinder to a point, so I could hit that cage nut. Also, save your old 1/8" shims or get new ones cut, as the kit does not have those.
In The Ten Ring is offline   Reply With Quote
Old 05-27-2015, 07:38 AM   #7
bestchevyfan
Hey thanks guys for the info. Buddy
Old 05-27-2015, 10:51 PM   #8
swamp rat
swamp rat's Avatar
Call wes at Classicheartbeat.com he won't sell it unless he uses it.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-27-2015, 11:25 PM   #9
the hippie mechanic
the hippie mechanic's Avatar
I got mine from RockAuto. They're Energy Suspension brand and the bushings were great. The kit didn't come with bolts or the washers in between the cab and body bushing though. I've heard some kits come with bolts that are too short though so I was ok with it.
'71 Chevy C10, 250 straight six, 3 on the floor, long bed
'70 Plymouth Duster, 340 small block, 4 on the floor, 3.55 ratio 8 3/4 rear
"Rust is a major food group."
"Burn 'em if you got 'em."
the hippie mechanic is offline   Reply With Quote
