Old 05-25-2015, 12:20 PM   #1
70'
70''s Avatar
Front rotor and caliper upgrade options for 4X4
I have completed the rear disk conversion with a nice 13" Baer kit and I am looking to upgrade my existing disk brakes on the front with a similar kit but have not found anything. This truck is a 4X4 which seems to be complicating the issue. I'm sure someone on here has done it and may recommend a kit.
70' is offline   Reply With Quote
Old 05-25-2015, 03:16 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: Front rotor and caliper upgrade options for 4X4
Is your truck a 1970? If yes, does it have a drum brake front end?
If yes, your best bet is to swap an open knuckle disc brake front end under it. There was a company making kits called Blackbird's Custom Trucks but I think they folded.
If you're the creative sort you can piece together your own kit with OEM parts and a little fabrication.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
