Old 05-26-2015, 10:14 AM   #1
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
67-72 OEM Temp Sensor Mounting
I put a 4.8 in my 67 and am trying to figure out the best location for the temp sensor. The LS hole is 12mmx1.5 and the 67 temp sensor is 1/2 NPT. What is the best solution. I thought I had read about a smaller autometer sender but now I cant find it.
Thanks,
Ryan
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 05-26-2015, 10:50 AM   #2
Bagd72Chevy
C10 Collector
Re: 67-72 OEM Temp Sensor Mounting
Well looks like best option is:
Autometer 2277 and 2259 or drill/tap head. For anyone who finds this searching.
///Ryan
1971 Blazer - Rusty
Old 05-26-2015, 05:35 PM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
The 2259 sender may not work with the factory 67-72 gage.
I just drilled and tap the passenger side head to put in a replacement sender that was 1/2" npt.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-29-2015, 01:22 AM   #4
68c10airstream
68c10airstream's Avatar
my donor 2001 5.3 water pump had a nice flat boss facing forward that i drilled for the original 1968 sender. Worked perfectly except the factory gauge reads on the warm side because the ls runs hotter than they did in 68. After installing the sender and the factory gauge read warmer than i liked i cut the line before the sender and installed a variable resistor inline and added resistance and dialed the gauge back to half way when fully warmed up (195 degree). The value i added was 4 ohm 1/4 watt resistor from radio shack. Remember that all of the connections need to be nice and shiny, especially the head of the sender, and the exposed connector.
68c10airstream is offline   Reply With Quote
Old 05-29-2015, 07:07 AM   #5
Bagd72Chevy
C10 Collector
I wanted to follow and say I put the autometer sending unit in my 1967 C10 with factory gauge. At 180° the needle is on the line on the left side. That is verified with a tech2. I haven't gone and driven it to get hotter but so far so good.
///Ryan
1971 Blazer - Rusty
Old 05-29-2015, 10:06 AM   #6
aggie91
aggie91's Avatar
Good to hear that worked. If you are happy with the reading, I say, job well done!
Karl
The LST Challenge:
