Old 05-26-2015, 10:27 AM   #1
WarMonger
WarMonger's Avatar
motor mounts for 383 stroker
So I just pulled the 350 out of the truck. I'm going to put a 383 I just built in it. Questions, my motor mounts are shot out on the old engine. Should I buy OEM ones (like from LMC) or is there a aftermarket set-up I should run with?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 05-26-2015, 10:53 AM   #2
wbc409
Re: motor mounts for 383 stroker
I believe energy suspension makes polyurethane mounts.
Unless you are going to be abusing the truck I would go down to the parts store and get stock replacements
wbc409 is offline   Reply With Quote
Old 05-26-2015, 11:06 AM   #3
WarMonger
WarMonger's Avatar
I'm not going to abuse it, but she has 425 horse, so I'm gonna let everyone know about it.
1970 C20
-_--_--_- ______
1972 K5
Old 05-26-2015, 11:17 AM   #4
leftybass209
leftybass209's Avatar
The stock parts store mounts (anchor brand) are poor quality in regards to fitment. I remember reading there was a recall on the original motor mounts, which required an added chain in case the drivers side broke. A better design would be the clamshell or car style (which require aftermarket engine stands).
leftybass209 is offline   Reply With Quote
Old 05-26-2015, 11:31 AM   #5
WarMonger
WarMonger's Avatar
where can I get these from?
1970 C20
-_--_--_- ______
1972 K5
Old 05-28-2015, 12:03 AM   #6
Fitz
Energy suspension has the polyurethane mounts you will need for that 383. Available from either Jegs or Summit Racing. You can try the OEM rubber ones but they will likely tear as they don't like the torque that motor will make.
Fitz is offline   Reply With Quote
Old 05-28-2015, 05:51 PM   #7
MAC71
MAC71's Avatar
I had stock mounts on a 71 that had a 406 small block that ran high 12's. I broke the drive shaft, a couple of transmissions and a differential but never the mounts.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
MAC71 is offline   Reply With Quote
Old 05-28-2015, 05:52 PM   #8
MAC71
MAC71's Avatar
I would like to add that I have a 69 c20 with stock small block mounts on a 396 and no issues.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 05-28-2015, 07:06 PM   #9
michael bustamante
michael bustamante's Avatar
if youre thining of having the factory engine strap that mount to the driver side of the frame and block i do have one im not going to use.
1967custom
michael bustamante is offline   Reply With Quote
Old 05-28-2015, 09:41 PM   #10
sasquatch58
Lakewood makes 1/2 solid-1/2 rubber mounts for chevelles..i don't know about truck applications.never mind..i checked for you.just cars only
sasquatch58 is offline   Reply With Quote
Old 05-28-2015, 10:27 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
The photo above is a car type mount, not truck. IMO, if I was going to install a high horsepower engine and wasnt worried about originality, i wod go with the 73 up modern captured mounts. This would require new sbc stands and possibly some fabrication (holes drilled in frame. Otherwise I would go with polyurethane mounts for the stock 67-72 type.
WIDESIDE72 is offline   Reply With Quote
Old 05-28-2015, 10:29 PM   #12
WIDESIDE72
WIDESIDE72's Avatar
http://m.ebay.com/itm/400767514465?nav=SEARCH
Old 05-28-2015, 10:34 PM   #13
WIDESIDE72
WIDESIDE72's Avatar
http://m.ebay.com/itm/271882216467?nav=SEARCH
Old 05-28-2015, 10:39 PM   #14
Fitz
I have a slightly larger and more powerful engine in my 67 that went through two sets of OEM mounts before I switched to polyurethane and ended that problem. This truck ran in the mid 11's until I tubbed it to got enough rubber under it. Then it brokr 10.99 and I got banned for no roll cage. Go figure.
