Old 05-26-2015, 01:36 PM   #1
Mick Je
Mick Je's Avatar
What gears are you running?
I'm in the middle of building a 454 engine for my 70 GMC, I currently run 3.73s but going on the freeway it screams at 3k. I have a TH-400 with 30in tire's on the back, I'm trying to decide to put 3.42s and use 3rd like an overdrive or put 3.55s. Just wonder what some of you guys were running and what rpms you are running at 70.
343 NEVER FORGET 9-11
FIGHT ON!!! GO USC!!!
PROUD OWNER OF A 1970 1/2 TON
Mick Je is offline   Reply With Quote
Old 05-26-2015, 04:46 PM   #2
Tkmadone
Re: What gears are you running?
I am currently running a 3.54 Dana 60 in my C20 and I was turning about 3k at 65 with the T400. I just installed a 2004R and now it's 1800 rpm at 65, about 2000 at 70. So now I'm looking for a 4.10 rear!
If you put in a 3.54 it will only drop you from 3k to 2850 rpm. Your best bet would be 3.07, which will drop you to 2450 rpm from 3k, or an overdrive transmission.
Tkmadone is offline   Reply With Quote
Old 05-26-2015, 04:50 PM   #3
CST10
CST10's Avatar
I'm running a 454 with a T350 tranny. Rear gear is 3.07. Runs about 2500 rpms at 70 mph.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 05-26-2015, 04:51 PM   #4
Fldawg
Fldawg's Avatar
Like you i had 3:73's in mine went to 3:42's and only lost 200 rpm maybe 300
Fldawg is offline   Reply With Quote
Old 05-26-2015, 05:02 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The engine will handle 3,000 RPM's all day long. But will your wallet handle it as that BBC is drinking fuel?
If it's an engine "longevity" issue you're worried about... I would think it's a non issue. But if you want better MPG's then I'd look into an overdrive transmission that will handle BBC TQ.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-26-2015, 07:35 PM   #6
Mick Je
Mick Je's Avatar
Do you have to drive it in second around town (under 50 mph)?
Old 05-26-2015, 07:38 PM   #7
Fldawg
Fldawg's Avatar
no, mine is fine, i'm running a stall converter i have no probelms
Old 05-26-2015, 07:41 PM   #8
jocko
jocko's Avatar
Get the best of both worlds - 3.42 (or stock big block gear of 3.54) and WITH an od trans. Highway cruising without earplugs and more bottom end torque multiplication that you'll ever want or need. Just the gear change alone won't net much of a difference cruising rpm-wise. If that's all you're concerned with, o/d trans is the way to go.
Old 05-26-2015, 08:04 PM   #9
Mick Je
Mick Je's Avatar
Im sticking to the TH-400 there good solid trans, and maybe later on bolt a gear vendor to it. The only 4 speed trans I would consider is a 4l80e and put the MSD or B&M electric controller on it. I still pull boats and haul stuff with my truck, and never have been a fan of the 700r. For now I'm just going to change the gears.
Old 05-26-2015, 09:27 PM   #10
CST10
CST10's Avatar
Like I said earlier. I have 3.07's and can roast the tires a good 50-60 feet and still have to let off to hook up. Just so much torque that 454 will make is unbelievable.
MyToys:
Old 05-26-2015, 09:28 PM   #11
CST10
CST10's Avatar
I had thought of changing to 3.42's at one time but it won't hook with 3.07's. It will be worst going lower for me.
MyToys:
Old 05-26-2015, 10:03 PM   #12
In The Ten Ring
I have a 4.11 rear end. Terrible gas mileage but dad says my truck "will pull WV hills easily."
How can I add an overdrive gear to my 3OTT?
In The Ten Ring is offline   Reply With Quote
Old 05-26-2015, 10:03 PM   #13
Mick Je
Mick Je's Avatar
What are the diameter of your rear wheels?
Old 05-26-2015, 10:52 PM   #14
enigma
3:73 with 700r4 1800 rpm at 60.
enigma is offline   Reply With Quote
Old 05-27-2015, 07:44 AM   #15
I run 4.10s and run 65 mph all day long. In my newer vehicle with overdrive (& 4.10s) I also run at 65. I use overdrive for it's intended purposes, reduced wear & tear and better mileage, not to go faster. On my '67 I have 3.42 with an M22. That is as tall as I would go for a manual trans. It will accept an overdrive well and will be fine in case that never happens. The '72 has a mild 350 and the '67 has a ht little 327.
Figure these trucks in 1/2t came with 3.08s behind a 402/TH400 and 3/4t came with 3.54s. 3.08s rare lanky for my taste but certainly fine behind a 454. The more torque, the taller gear you can get away with
Old 05-27-2015, 08:40 AM   #16
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Very Wise.
Tom Vogel is offline   Reply With Quote
Old 05-27-2015, 10:54 AM   #17
Fitz
I run a turbo 400 backed up by a gear vendors overdrive which gives 2300 RPM at 70 mph.
This link will take you to a gear ratio calculator which will help you figure this out.
http://www.grimmjeeper.com/gears.html
Fitz is offline   Reply With Quote
Old 05-27-2015, 01:29 PM   #18
Mick Je
Mick Je's Avatar
Sweet!
We have one on our Motorhome and it's nice!!! That's what made me think about putting one on my truck. They are pricey but are worth the money to me!
Old 05-27-2015, 02:29 PM   #19
Fitz
Sweet!
With my truck it's a necessity. The torque from the ZZ572 up front would grenade a 700R or a 2004R so, 4.10 gears for quick starts and a 0.7:1 overdrive is just the ticket.
