Old 05-27-2015, 10:08 AM   #1
woody82
Rear end vibration
My 72 half ton has had a vibration since I bought it.I finally tracked it down its in the rear end.Any advice would be helpful. Thank you.
woody82 is offline   Reply With Quote
Old 05-27-2015, 10:48 AM   #2
67 chevelle
67 chevelle's Avatar
Re: Rear end vibration
Tires , shocks , bushings , axle bearings ,,, are what I would check first
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-27-2015, 10:58 AM   #3
Fitz
Then check the U-joint on the pinion flange. It is more likely driveshaft or bearing related than something inside the diff housing. Problems there are usually accompanied by very loud and unplesant grinding noises that don't last long. Then the truck doesn't move under it's own power.
Fitz is offline   Reply With Quote
Old 05-27-2015, 11:50 AM   #4
cooperhw
cooperhw's Avatar
You could try measuring how high off the ground it sits. Then jack it up and remove the tires. Put the lugs back on the drums to hold em in place as well as balance. Then lower the rear end onto jack stands about the same height and chock the front wheels. Put it in gear and up to speed. See if it's still vibrating. If not it's in the wheels and or tires. If so, it's deeper. Might want to go to a rear end shop for an estimate.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
