05-27-2015, 02:32 PM | #1 |
67 c10 brake upgrade
I'm converting a 67 c10 manual drum/drum to power disc/drum. I have an 87 donor for parts to make the swap. Is there an adapter needed to make the 87 power booster and master cyl bolt to the 67 firewall or will it be a direct fit ? Thanks
Posted via Mobile Device |
05-28-2015, 08:34 PM | #2 | |
The Older Generation
Re: 67 c10 brake upgrade
It is not a direct fit. There are some threads on here and maybe a "How to" in the FAQ section on the swap. I think it takes some fab work.... I have never done it. I think I would just get the booster/master from a '71 or '72, that way you will have all of the correct brackets and rods. Be sure and get the rod from the pedal to the booster as it is different also.... LockDoc
05-28-2015, 09:01 PM | #3 |
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
