Old 05-27-2015, 08:03 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
97 Tahoe evaporator replacement?
Anyone done this job? I have a leak and cant find it anywhere. that's the only place left I cannot see.. I replaced the compressor some time ago and charged the system to only leak out with in two days. All other fittings look clean and free of oil.
How much work is it to even inspect the evaporator?
Thanks for any help with this one.. Summer is coming fast!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-28-2015, 06:31 AM   #2
speedygonzales
speedygonzales's Avatar
Re: 97 Tahoe evaporator replacement?
You can check with either a "sniffer" used in the vents or pressure and dye.
You can also get to the ends of the evaporator and try applying vacuum to one end and plug the other. Use a rubber cork available at any good hardware store. With a plastic hose barb in one cork, use a mity-vac hand vacuum pump.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 05-28-2015, 12:57 PM   #3
61_FL_Apache
Who Me?
I do have dye in the system, but cant see it anywhere. The only place I cant see is in the evap area. I dont have a sniffer to use.
Steve
2001 Blazer 4D 2WD
Old 05-28-2015, 03:09 PM   #4
speedygonzales
vac it. Don't change it till you prove it.
Pride and joy
Old 05-28-2015, 07:04 PM   #5
61_FL_Apache
Who Me?
It will lose vacuum fairly quick.
Steve
2001 Blazer 4D 2WD
Old 05-29-2015, 06:14 AM   #6
speedygonzales
I understand the system looses vacuum. What I explained before was use 2 rubber corks and a hand vac at the 2 evaporator connections. Not to vac the entire system. Get it?
In this way you check only the evaporator before you waste time pulling it for nothing.
Now do you understand?
Pride and joy
Old 05-29-2015, 06:33 AM   #7
61_FL_Apache
Who Me?
Gotcha!
Steve
2001 Blazer 4D 2WD
