05-27-2015, 11:20 PM | #1 |
Sandlewood
HiGuys,I have a 70 gmc it is dark bronze and has a sandlewood interior. are dash pads,rubber floor mat,dash bezel, avialable in this color? id like to stay the same.i,ve had this truck for a long time. just started driving it again,and now im wanting to do some work to it. thanks for any info. BROWN 70
05-27-2015, 11:34 PM | #2 |
Re: Sandlewood
Unfortunately, no - it is not a reproduced color that I am aware of! See steering column and rubber floor mat in my 71' Chevy. GMC might be a different shade? I wouldn't know without seeing. Arrow below pointing to original factor vinyl paint on floor mat.
71' Custom Deluxe C10 Sandalwood
project: "my happy mess" |
05-27-2015, 11:52 PM | #3 |
Re: Sandlewood
Brother's Trucks used to sell a sandalwood dash pad repop. I didn't buy one, so I can't attest to color correctness or quality. I just looked and they don't show the sandalwood as an option on their website right now, but if you select the "color samples" it still shows there. Might be worth a call to ask.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
05-28-2015, 12:47 AM | #4 |
Re: Sandlewood
If you are trying to restore a 625 gold trim interior you are probably going to have to dye any reproduction parts you find.
Hopefully you have some good samples to match to. Floor mat is the hardest thing to find in anything but black but I have seen some aftermarket replacements in tan and grey.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-28-2015, 09:04 AM | #5 |
Re: Sandlewood
So is that a painted steering wheel?
05-28-2015, 11:17 AM | #6 |
Re: Sandlewood
That's a factory sandalwood steering wheel (which nobody sells). You can (if you have original sample) get a local store to mix up some vinyl paint.
05-28-2015, 10:33 PM | #7 |
Re: Sandlewood
Thanks Guys, i still have the same steering wheel as in the picture. will i need paint and dye for the dash bezel/pad. im thinking it might be very tough to dye a floor mat? tim, where are the tan floor mats available? thanks again guys. Mike
05-28-2015, 11:06 PM | #8 |
Re: Sandlewood
Sounds like a nice truck and color combo. One of the only other people who I know of with a dark bronze truck (I don't believe there are many of them) . I don't know if you want to go this route ,but SMS upholstery has the correct original color. I looked into it a while back and ended up doing something different.
05-28-2015, 11:43 PM | #9 | |
Re: Sandlewood
So here is your free link and stated refund value! :-) http://www.stockinteriors.com/items....Vinyl_Flooring They also have it for Blazers and molded carpet including the tank removal guys. Explore away.
