Old 05-28-2015, 12:28 PM   #1
hartleymetalworks
anybody running pb dm level 1(mild) with bags?? pics??
i need to make up my mind on which pb dropmember to order, ive been on the fence for a while now. kinda leaning toward the (mild)level 1 kits. nate has emailed me a few pics of a truck aired out and i like it. but i was wondering if anybody has any pics of one at ride height and aired all the way up. also like to get some input from anybody that has done it. problems, helpful insight, thoughts, recomendations welcome
hartleymetalworks is offline   Reply With Quote
Old 06-10-2015, 05:00 PM   #2
DLW
Re: anybody running pb dm level 1(mild) with bags?? pics??
I'm installing one right now on my 66 C10. I just finished fit checking it all and installing the steering shaft 3 joint setup for the uni-steel power rack and pinion. Don't have any pics yet on the ground though. Here is what I noticed so far though, with a 28" wheel, it looks like the wheel/tire would go above the inner fender by an inch or two. If your keeping your inner fenders (and not trimming your outer fenders) then bump stops will be needed. I am switching to a shock that you can add a bump stop too that hopefully works just to keep it clean and also get me double adjustable shock in the process.
If your also going to use the PB stage 2 deluxe kit to compliment the mild drop member, then it comes with bump stops that keep the rear Diff from hitting the bed floor. If you raise the bed floor and remove the bump stops from the c-notch, you can get another 1.5" of drop aired out.
With that said, the PB stuff all fit great and Nate was always there to help me out with questions or issues. My LS3 fit in the drop member perfect. The 3 joint steering setup is a PITA depending on what headers you have, my DT headers didn't leave a lot of room for routing. I think having or installing a high hump is a good choice even for the mild setup.
Doesn't seem like to many of us mild drop guys around. Good luck with whatever your choice is.
DLW is offline   Reply With Quote
Old 06-18-2015, 02:00 AM   #3
invicta455
Let's see some pictures of your installation on your rig
invicta455 is offline   Reply With Quote
Old 06-19-2015, 05:55 PM   #4
DLW
Nothing to pretty to show but here is a few that I took. I'm at the point of pulling it all out for powder coat now.
3 joint steering mocked up
