Windshield Wipers Quit
My wipers quit the other day, Fuse blew.
I can't imagine why....... ![]() Thanks PO!! ![]() ![]() ![]() UNHappy Hooligan
The Green Hornet 1960 Apache 10 Long Fleet - Driver and Work In Progress The Death Star 2006 Vstar 1100 - Chopped, Bobbed, Riding the Dark Side |
Post Whore
![]() Join Date: Mar 2013
Re: Windshield Wipers Quit
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Whats even more fun is pulling out the whole bunch of them in one shot on the side of the highway the because one catches on fire and ya can't tell which one it is! At least it was fused.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
Very true. At least no fire, but after looking closer I'm sprites there hasn't been.
I'm just hoping when I get it sorted the motor isn't fried!! Hooligan
Mine started with my buddy asking why my "courtesy lights" were on in my '57. It didn't have "courtesy lights" lol.
My '63 had the same mess when I got it. Took one wire out at a time until it didn't run... then put that wire back in.
#6 | |
![]() Join Date: May 2007
http://en.wikipedia.org/wiki/Muntzing
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
That's how I cleaned up wiring on my bike. It's kinda fun. Makes the wife nervous though haha
Ill be sorting and cleaning it up at the same time, hopefully with it still running as it is my primary enclosed vehicle. Hooligan
#8 | |
Hooligan
#9 | |
Thanks for the link Joe!
SO I finally got a chance to dig in to the Spaghetti bowl.
found some good things and a whole lot of bad things. Good things Wiper Motor is NOT fried!! Heater Fan does work Bonus ![]() made some test leads and got both of them running. Bad things..... everything else ![]() There appears to be at least 3 different sets of Wires, probably get $50 if I pull it all and sell the copper Pulled wiper wiring from bundle and found no breaks or bare spots to show where short was. hooked up outside of bundle and works fine ??? Discovered when i move the wires something shorts to radio and it will turn on and shock the *#%@ out of me. Plan is to run some flex conduit under dash and start rewiring one system at a time as I go through them and get it right. might still go for a new harness down the road but it is not in the budget right now. I know some of you have done this and any tips would be appreciated. Also looking for recomendations for replacing the fuse box, this one is pretty busted up and nasty. Thanks Hooligan
OK we are back to the same issue only worse!!
Wiper tested fine, until first time I actually needed them. About 5 minutes into torrential downpour SMOKE !!!! Melted Insulation on the hot wire to the motor, before fuse blew. Test leads allow motor to turn still but now I am afraid to drive my rainy day ride in the rain. Would a leak around the motor somehow be allowing it to short? Hooligan
Are you getting water in where the wiper motor is mounted? Its a fairly easy fix if it is.
Remove the wiper arms. Remove the cowl panel in front of the windshield. Disconnect the wiper transmission arms from the motor (1 nut). Go under dash and remove the wiring from the motor and there are 3 small bolts that hold the motor to the dash. Reinstall in reverse. I upgraded my single speed to a dual speed a few weeks ago. Was a one man job. Main thing is to not change the timing on the motor / linkage. If you do, its easy to reset, but must be done with the motor out. You'll see 2 hash marks on the face of the motor (faces the firewall) that will be 90* of each other. The linkage will have 2 hash marks also and they just need to mirror each other. This will ensure the wiper arms travel the correct path and return where they are suppose too.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#13 |
Heres a pic of the timing tabs (look at 3 and 6 o clock positions) I was talking about. The linkage that attaches to the motor will also have these marks. Just make sure they mirror each other if you feel its moved any on removal.
#14 |
Thanks c-10. Not for sure about the water, but its my guess, because only seems to happen in hard rain. I didn't get a chance to dig under there when it was fresh to check for moisture.
That bit about the timing marks is why I was worried about taking it apart without asking on here. Thanks for the pic!! Hooligan
#15 |
No problem. Hope you get it resolved. If you get hung up, just PM me and I'll do my best to help out.
#16 |
I was Able to get the motor pulled the other day and finally had time to tear it down yesterday.... but forgot to take pics. (still have it out Ill get some pics later)
All the seals were shot and the little rubber pieces that hold motor to firewall fell apart and motor fell off with out removing the hardware. Disassembled the motor and transmission parts. found the main shaft that turns linkage had some corrosion and was pretty rough and hard to turn. Also the tops plastic gear teeth are folded down about 1/4 of the way around. think I did this when I was trying to take the drive arm off unfortunately. I think I got it rebuilt and cleaned up enough to work, until I can upgrade to 2 speed motor. Everything I have been able to find says 63 and up, which I understand is when the 2 speed came out so that makes sense. Read through threads in FAQ and still not sure. Will one of these be a direct replacement on the 60? the motor in mine sits parallel to firewall if that makes any difference. Thanks Hooligan
#17 |
As far as I know the 60-63 motors are interchangeable. The 3 rubber bushings are available aftermarket that hold the motor to the firewall. Make sure to reattach the ground (fits under the right side bolt).
And the 2 speed motors were optioned in 1960-66
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-24-2015 at 09:44 AM. |
#18 |
As Always thanks C-10!!
One of these days I'll come up with something that you cant answer in 5 mins.....maybe. Hooligan
#19 |
hahaha.....its no problem. Just glad I can help. Theres lots of questions I have to get answers for here myself. And very few days I don't learn something new on this forum myself. I've been dealing with these trucks since I was 12.....be 37 on July 6 and had my first 63 stepside titled in my name at 16.
