Starter issues
I have a 72 c10 with a 350/th350. When I start the truck it makes a horrible grinding sound. The truck starts right up within a second or two but it makes that grinding sound. What could it be? A bad solenoid? Completely bad starter? Or just might need a shim job? Just wondering what you guys think?
![]() ![]() Join Date: Feb 2009
Re: Starter issues
My first thought is shims. But if it worked before and doesn't now, then that doesn't seem too likely. If it were me and it's been a while since the replacement, I'd replace the starter.
Believe it or not, I had one experience where it was a bad starter AND battery. Seemed the battery wasn't providing enough juice and contributed to grinding. That was back in the day I thought a cheap battery works as well as an expensive one.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Starter issues
Get under it, remove the cover and look when the gear engages.
Re: Starter issues
First thing I'd check for is loose starter bolts. If it's not that do what Franklin said.
Re: Starter issues
When my starter went out it started with same symptoms
________________________ 72 Olds Cutlass w/442 option 69 C-10 Short Bed Fleet 1960 Biscayne Wagon/El Camino 1995 YJ 4.0 SOA SYE on 35s 01 Excursion Limited 7.3 PSD 06 Suzuki DRZ 400S |
Re: Starter issues
I used to get one like that occasionaly back when I had a shop. It usually caused by the gears not meshing deep enough. Replace the drive on the end of the starter & make sure the bushings are good. Take a large rough file & go across the mounting surface of the starter. The metal gets pulled up & lowers the starter away from the flywheel. That generally fixes the problem. If you go to far which never happened then you can use a shim. These starters are not hard to work on yourself.
#7 | |
Re: Starter issues
Re: Starter issues
Ok thanks for all the feedback you guys. I think I might just buy a completely new starter and start from there.
Re: Starter issues
If I did, I would buy a later gear-reduction type instead of the original. If you have an HEI or similar distributor that will be no problem. If you have an original style distributor, then you have to deal with the start circuit to the coil.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#10 | |
Re: Starter issues
Note: Get a good starter (not cheap) if it comes to that. Like I said, I installed it three times with the last replacement. Heck, it might have been four times (twice for adjustment). Somewhere in the middle I replaced the battery with a GOOD one as well. I'm no mechanic, but solid juice to the starter seemed to have had some impact on the gears. Less drag I guess.
Re: Starter issues
In what way does gear-reduction reduce gears?
![]() Join Date: May 2015
Re: Starter issues
While your under there checking on stuff, check all the electrical connections and wires...including grounds. Poor/reduced power delivery can cause weak/short gear engagement, etc.
Grinding noises = bad juju. Dey say, "Fix me now! If dey stop: de gods have judged your wallet be too full!" ![]()
===Marc '55 Buick Roadmaster Riviera 76R '69 Chevy C-10 CST/10 396 LWB, auto, air, PS (PB soon!) |
