Rear axle lowering blocks for a C20....
Does anyone know where I can get some that actually fit. Most say they fit, but with the fatty rear end on the 3/4 ton...the don't fit. Anyone know where I can get some from? Thanks!
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Rear axle lowering blocks for a C20....
What differential is under your C20? The trailing arms are interchangeable between C10's and C20 as well as the U-bolts, so I don't understand why the typical blocks won't fit. Unless your truck has a different differential under it. I doubt that anyone makes lowering blocks specific to a C20 so if need be you will likely have to have some made to fit your truck.
I guess I should have been more specific. The blocks are not the problem, it's the U bolts that are the problem. The U bolts are too small (narrow) and do not go around the axle. If I could just get U bolts that fit, that would be great.
I got mine at NAPA
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
![]() Join Date: May 2010
Any local spring shop should be able to make you new U bolts.
It only has original paint once |
Thanks guys...I will try NAPA and a local shop.
