![]() Join Date: Apr 2015
69 gas tank? moved to under the bed
Does anybody know if a 40 gallon suburban tank will fit on my 69 shortwide between the frame? please let me know. thanks, Steve
Re: 69 gas tank? moved to under the bed
Dave did a thread on installing one in his K series pickup (lwb).
http://67-72chevytrucks.com/vboard/s...d.php?t=551269 Plus there were 40 gal replacements for Blazers (like the picture) so it should be possible to fit that much. But you will probably need a tank intended for a Blazer like this one. http://ventura.craigslist.org/pts/4970040046.html Remember a big tank is heavy plus the fuel at 6 lbs a gallon.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
I had a 72 suburban that had the 40 gal tank pictured above. Tight fit and it would not fit in a short bed.
I have a 71 long bed right now that I installed a 1988 31 gal suburban tank and it fits quit well. A friend has a 67 short bed and he was looking at doing the 31 gal in his but after looking at mine he stated there was no way that tank would fit in his short bed. Here is a photo of the 31 gal in a long bed frame. ![]()
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
oK thanks, for the replies
