05-28-2015, 08:59 PM | #1 |
Problems with vintage air
Just finished installing my vintage air on my 66. Fan speeds and blend controls work great. Heat blend works good, but I can not get the compressor to come on with the controls. The compressor will start if I connect it to the battery. That is how I got the charge filled. Any ideas.
05-28-2015, 09:45 PM | #2 |
Re: Problems with vintage air
Either to high/low of pressure or bad binary switch. see if your getting power to the binary switch.
Between saying and doing many a pair of shoes are worn out |
05-28-2015, 10:10 PM | #3 |
Did you program the controls after installation? If you use the factory type controls you need to. If you use the V-A universal controls you are not supposed to have to, but I did on mine. If you call V-A they will help you with it. They are very nolageable & helpful.
05-29-2015, 12:02 PM | #4 | |
Chevy addict
X2 The only call should be to Vintage AC, they ARE the ones to help you before any suggestions can damage the unit. |
05-30-2015, 06:32 AM | #5 |
06-01-2015, 05:00 PM | #6 |
I did some troubleshooting over the phone with vintage air, they are sending me a new ecu when I send the old one back for testing
