Old 05-28-2015, 10:12 PM   #1
jcblue
jcblue's Avatar
Windshield stainless .. Could it be better? I hope so.
I'm not really satisfied with my new stainless.. There are gaps that I don't think should be there.. Is this as good as it gets or am I being too picky?
jcblue is offline   Reply With Quote
Old 05-28-2015, 10:13 PM   #2
jcblue
jcblue's Avatar
Re: Windshield stainless .. Could it be better? I hope so.
Closer pic
Old 05-28-2015, 10:14 PM   #3
jcblue
jcblue's Avatar
Side view
Old 05-28-2015, 10:16 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
It seems to me that oem does in fact fit tighter.
WIDESIDE72 is offline   Reply With Quote
Old 05-28-2015, 10:26 PM   #5
diggerbob
diggerbob's Avatar
looks a lot like mine after I got it redone with OEM trim from 67-70 and precision gasket. The prior install used a non-precision gasket and 71-72 after market trim. It looked good from the outside and the trim laid flat but it leaked like hell when I drove it in the rain.
diggerbob is offline   Reply With Quote
Old 05-28-2015, 10:31 PM   #6
68c10airstream
68c10airstream's Avatar
Look at the upper corners on the inside. Are they seated nicely and look correct?? My windshield rubber corners looked somewhat like yours and i had to go back after a new windshield was put in and pull on the corners to get them to lay flat against the body on the outside. Good luck Brian F.
68c10airstream is offline   Reply With Quote
Old 05-28-2015, 11:12 PM   #7
tommys72
tommys72's Avatar
That's about what mine look like, aftermarket trim and gasket. Irritatesthe crap outta me. Leaks when wet too
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 05-29-2015, 12:15 AM   #8
HeavyD
HeavyD's Avatar
I would hope the fit of pieces, even aftermarket, would be better than that. The gap is terrible..must be a better solution?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 05-29-2015, 05:55 AM   #9
cdowns
cdowns's Avatar
I carefully hit on it both the trim and gasket with a rubber mallet to get a better fit
carefully is the byword here
Old 05-29-2015, 09:43 AM   #10
pdawg
Judging by the photo I would think that it's not seated all the way down. You can see a faint line on the vertical trim that looks like it should come down another half inch or so. Then she should lay flat. Looks like a nice build! Good luck!
pdawg is offline   Reply With Quote
Old 05-29-2015, 12:32 PM   #11
jcblue
jcblue's Avatar
Thanks pdawg.. It's been a long one and I'm trying to make it as nice as possible.. It's my first..
Old 05-29-2015, 02:42 PM   #12
pdawg
The first one's always special !
