05-28-2015, 10:38 PM | #1 |
What are these for??
I was under my truck adjusting the brakes and noticed these brackets beside the bump stops on the frame.what are they for??
05-28-2015, 11:05 PM | #2 |
Re: What are these for??
for heavy loads
05-28-2015, 11:48 PM | #3 |
I didn't see this thread ,,, I just started one asking the same question .
05-28-2015, 11:52 PM | #4 |
Sorry if its a stupid question, but how does it help with heavy loads? Is it in case the bump stops dont hold up ,it prevents the frame from sitting on the axle?
05-29-2015, 12:30 AM | #5 |
What piece are you asking about?
There is a helper spring at the left of the picture. But the thing next to the bump stop is the panhard bar. It keeps the rear end centered, so it doesn't move to the side, especially when cornering. The bump stop is the bullet shaped piece of rubber hanging down from the frame.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-29-2015, 12:34 AM | #6 |
Are you asking about this?
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
05-29-2015, 12:35 AM | #7 |
Im talking about the lil drop down bracket that is riveted to the frame beside the bump stop.if you follow the frame between the panhard bar and the coil spring cup you will see it right beside the bump stop
05-29-2015, 12:36 AM | #8 |
Yes! Thank you. I have no clue how to edit pictures like that haha
05-29-2015, 11:21 AM | #9 |
I'm interested in finding out also. I don't have these on mine, and haven't seen a reference to them before.
05-29-2015, 12:36 PM | #10 |
The Older Generation
Is it the same on both sides? LockDoc
05-29-2015, 12:55 PM | #11 |
Leon, apparently, yes. Interestingly enough, there's another recent thread asking about the same backets, and the pictures on that thread show them on both sides.
clips or brackets on frame ?
05-29-2015, 02:25 PM | #12 |
Subscribed
05-29-2015, 02:27 PM | #13 |
70+ ( Old Skool Club )
Subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-29-2015, 02:39 PM | #14 | |
I will have to check my frames and see if any of them have them.... LockDoc
05-29-2015, 08:50 PM | #15 |
Yes they are on both sides. I have not seen any other refrence to them nor do i see a real purpose yet.
05-29-2015, 09:00 PM | #16 |
Are they exhaust hanger brackets?
1972 Chevy C/10 350 |
05-29-2015, 09:08 PM | #17 |
^ My guess
What kind of truck are we looking at here?
project: "my happy mess" Last edited by litew8; 05-29-2015 at 09:16 PM. |
05-29-2015, 09:19 PM | #18 |
Unless it's a big block it didn't come with dual exhaust.
05-29-2015, 09:25 PM | #19 |
It's a GMC, all I can tell.
project: "my happy mess" Last edited by litew8; 05-29-2015 at 09:33 PM. |
05-29-2015, 09:28 PM | #20 |
Aren't thry the mounting pads for overload springs, on my 68 parts truck it had overload coil springs and that is right where they sat.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
05-29-2015, 09:38 PM | #21 |
Got a pic no1udknow? Never heard of overload spring mounting pads.
I've heard of helper springs but they look like this...
project: "my happy mess" |
05-29-2015, 09:55 PM | #22 |
It is a 1972 gmc c20 all original.it has a 350 with a th350 trans and coil spring susppension amd dana 60 rear end. It has the helper spring behind the axle.
05-29-2015, 09:58 PM | #23 |
I have never seen those, the 67 parts truck I had had coil springs mounted on the axle. They were small and they rode on the frame. I wish I had a picture.
05-30-2015, 10:43 AM | #24 | |
They are the "positive stops" for the rear suspension travel. The rubber bump stop is a graduated rate. The positive stop is for when you've used all the rubber and need to prevent overtravel. It is an attempt to save the rubber attachment to live for another day and/or localize any frame damage to a part that can be replaced. You will find a positive stop next to the rubber bumper on the front lower control arm, too (different design but same concept). At least on the square bodies, anyway. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-30-2015 at 10:55 AM. |
