05-29-2015, 06:58 AM | #1 |
tallest tires
I have a 1972 c20 longhorn. it has rear leaf springs. I am about to install late model aluminum chevy 8 lug factory wheels. waiting on new lug nuts to get here. I want the tallest tires I can fit on it . it has like a 4/11 gear in it. trying to make it more highway friendly.going to buy new tires soon. any ideas on how tall of a 16 in. tire I can run ?
05-29-2015, 08:33 AM | #2 |
Re: tallest tires
The problem with getting tall tires is they want to get wider! I ran 265 75 16 on my C2500 all around. Another choice would be 255 85 16. If you want to stay skinny, the 235 85 16. But you are still stuck around 32-33" tall.
HO52 or Dana 60 rear in your truck? I have a parts truck with a 60 so not sure if that's the only option. But you can at least get lower numerically gears for it unlike the HO52. Pick the tire you want/like for the wheel and stance your truck has then keep your ears open for a 3.54 geared Dana 60 which was a great combo in my truck with 402/TH400. Posted via Mobile Device |
05-29-2015, 09:56 AM | #3 |
Re: tallest tires
Are you keeping or selling this one?
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
05-29-2015, 10:07 AM | #4 |
Re: tallest tires
I have 7.50x16 tires with 4.57 gear stock.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
05-29-2015, 10:18 AM | #5 |
Re: tallest tires
7.50R16's are right on 32" tall, 235/85's are a smidgen shorter and wider and 255/85's are almost 33" and wider still.
The tire we need is an 8.25R16. They are the same width as a 235 but almost 34" tall. The thing is, I have searched far and wide and have yet to come across a radial version for sale here in the states. Overseas they are a very common size. |
05-29-2015, 11:31 AM | #6 |
Re: tallest tires
My 71 C20 longhorn with rear leaf springs runs LT285/75R16 and they fit just fine with no rubbing on 16X8 0 offset wheels. They are 33" high by about 11.5" wide.
1971 Cheyenne Big Block Longhorn |
05-29-2015, 03:01 PM | #7 |
Re: tallest tires
05-29-2015, 03:15 PM | #8 |
Re: tallest tires
Remember while tire height (rolling radius actually) is a determining factor in how fast or slow and engine turns at speed (65mph through 4.11s in these examples). You need to do the numbers and don't expect much change.
http://www.summitracing.com/expertad...tio-calculator 30" 2985 32" 2798 33" 2713 34" 2633 36" 2487
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-29-2015, 03:20 PM | #9 | |
Re: tallest tires
05-29-2015, 08:45 PM | #10 |
My Spoon Is Too Big
Re: tallest tires
so your fitting a 33" x 11.5" at factory height? could that still fit if it was lowered 3"
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) |
05-29-2015, 10:39 PM | #11 |
Re: tallest tires
7.50R16 are the tallest. Closest metric is 215 85R16 but they are about an inch shorter.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
