05-29-2015, 08:28 AM | #1 |
Column shift to floor shift 1969 blazer question
My linkeage is all slopped out in my 69 blazer column shift so I ordered a B&M 80775 universal floor shifter for it. Does anybody know if there is additional hardware I will need to hook it up to the transmission?
Thanks David |
05-29-2015, 09:29 AM | #2 |
Re: Column shift to floor shift 1969 blazer question
Wow!!
They're still making and selling those junk shifters. Save your time! Cheap overpriced junk. It won't last. For a 100 bucks more you could get a real shifter that comes with everything to bolt it on. http://www.summitracing.com/int/part...50bm/overview/ |
05-29-2015, 09:32 AM | #3 |
how tough would that one be to install on a transmission that is in chassis
05-29-2015, 09:34 AM | #4 |
truck is a 4x4
05-29-2015, 10:05 AM | #5 |
THat was only an example of a better shifter.
Lokar has many that might work for you. http://www.lokar.com/ Or check here. http://www.gennieshifter.com/ |
05-29-2015, 02:00 PM | #6 |
I built it
i have that lokar one (only in black) and im not to much a fan of it. wish it was ratcheting.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
05-29-2015, 02:03 PM | #7 |
72chevyk10, other than being non-ratchet what don't you like about the lokar? is it too easy to slip from one gear to the next?
05-30-2015, 10:02 PM | #8 |
I built it
the button on it is kind of a pain to press (especially in hot weather) it kind of jams up in spots and have to yank it, mostly just coming out of park though and its gotten alot better since i first put it in. but biggest dislike is if i put it in first for a "fun run" it is VERY easy to skip a gear, gone from 1st to 3rd and then 3rd to neutral cause i didnt know i skipped it. next shifter im going to try is the hurst racthet shifter with the 15in "truck" handle. think its the promatic or something like that.
oh and also had to get a seperate thing for the linkage to trigger the backup lights
