Old 05-29-2015, 11:22 AM   #1
briscuba
briscuba's Avatar
Mystery engine noise, hyd. lifters? Help guys...
Hi, factory 402BB/400TH, headers, 1970 CST/400
I posted this about a year ago and have some follow up. STILL a mystery to me, hoping someone can help please.
I am hearing a "ticking" noise in my engine compartment that I'd say sounds just like a sticky lifter. We've all heard this ticking before with hydraulic lifters... However, I recently replaced all my lifters and found a bad one (did a happy dance thinking I had it licked!) I did not change the cam. Valve adjustment done many times, timed well and sounds great. Runs great. STILL ticking. Ugh!! So annoying.
Here are some details:
1. quiet with covers off, adjusted fine, all 16 valves. quite with covers on.
2. increase ticking on acceleration, decrease on deceleration.
3. lifters new, exh. manifold gaskets new, header to muffler gasket new
4. sometimes makes no noise at all
5. hot or cold same symptoms
See pic, I've been told the low profile valve covers sometimes have clearence problems? Don't think it's speedo cable... Any ideas?
Thanks guys!!
1967 C10: My next project
1964 SS Impala Hardtop, low and slow
2007 Harley Street Glide .... When all else fails to start.
briscuba is offline   Reply With Quote
Old 05-29-2015, 11:42 AM   #2
Jonlopes
Re: Mystery engine noise, hyd. lifters? Help guys...
I am subscribing to this thread. My 402 is also making a deep ticking noise. You can only hear it when the hood is up (too quiet otherwise. The motor runs great and idles smooth. I have only had it for a couple of weeks so I have not started changing out parts to diagnose but am interested in possible causes.
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 05-29-2015, 12:24 PM   #3
trapdoor2
trapdoor2's Avatar
Mechanical fuel pump?
My antique brain sez we chased a tick over a couple of weeks (back when I was a kid) and finally discovered there was excessive clearance between the op-rod and the pump arm. As I recall, Dad had a machine-shop turn one for him that was just a little longer (or maybe he welded a button on the end and ground it to suit...I can't remember exactly). However, the tick went away.
===Marc
'55 Buick Roadmaster Riviera 76R
'69 Chevy C-10 CST/10 396 LWB, auto, air, PS (PB soon!)
trapdoor2 is offline   Reply With Quote
Old 05-29-2015, 12:30 PM   #4
kwmech
Are you sure it is not an exhaust leak with those headers. I had the same problem with mine and put on manifolds and a new exhaust. Quiet ever since
Old 05-29-2015, 12:31 PM   #5
briscuba
briscuba's Avatar
Fuel pump new.
Could be a rod, I did check them all too. Clearance could be an issue...
Old 05-29-2015, 12:48 PM   #6
Boog
laying low
Boog's Avatar
Fuel pumps can make a hard pecki g sound just like a lifter. Exhaust leak real possibility too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-29-2015, 12:54 PM   #7
trapdoor2
trapdoor2's Avatar
Taken a stethoscope to it? Much easier to track down odd noises with one. I was taught to use an extra-long screwdriver as a stethoscope...then I bought a special one for doing engine diagnostics when I was an A&P mechanic. Long gone...need to buy a new one. On sale this week @ Harbor Freight for $3.99!
===Marc
Old 05-29-2015, 02:13 PM   #8
Sklptrljay
Sklptrljay's Avatar
Do you have a mini-starter on it? I know that me and another board member had the same problem with the gear being to close to the flywheel.
It only made noise on acceleration and declaration.
It sounded like a ticking noise too.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 05-29-2015, 02:14 PM   #9
briscuba
briscuba's Avatar
Fuel pump was replaced, and I also think the sound is coming from the left bank. Or... maybe I am just closer to that side. I have no interior carpet, bare metal, sound travels easier from engine compartment.
Old 05-29-2015, 02:19 PM   #10
briscuba
briscuba's Avatar
I think it is a standard starter. What's a mini? Is that the induction starter? Interesting...
Old 05-29-2015, 02:29 PM   #11
Sklptrljay
Sklptrljay's Avatar
Just the aftermarket hi torque starter. I suppose any starter could do this, but I've never heard of a stock one doing it.
It was a real head scratcher for me. I was so relieved when that's all it was. I would have sworn the sound was coming from the rear of the truck. Just goes to show that sound travels and you can't ever be sure where it's coming from.
Old 05-29-2015, 02:44 PM   #12
briscuba
briscuba's Avatar
So in your case, the starter/flywheel issue would make noise while moving? Even in neutral, theoretically?
I am rarely surprised at the "what" or "causes" of issues. Many head scratchers out there. That's why we have this site. :-)
Thanks!
Old 05-29-2015, 04:02 PM   #13
7tee
7tee's Avatar
A way to make sure it's not the fuel pump rod is start the motor then shut it off. While fuel lines are still hooked up, remove the fuel pump from the block, the rod will slide down. Then start the motor to see if you can still hear the ticking (it will run for a short time with the fuel that's left in the carb). At least this way you can eliminate the pump rod...
7tee is offline   Reply With Quote
Old 05-29-2015, 04:10 PM   #14
88Ironduke
I have seen a bunch of threads on big blocks with a "ticking" noise that's been resolved to timing issues. The ticking being heard was actually pinging.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 05-29-2015, 04:21 PM   #15
Molberg
Molberg's Avatar
Check and double check your header gaskets at the cylinder head. Mine is "ticking" as we speak and I just installed them.
Molberg is offline   Reply With Quote
Old 05-29-2015, 04:44 PM   #16
65standard
65standard's Avatar
Agree with others, most of the time a ticking noise on a big block is from header gasket leaks. I never use those mr gaskets paper type gaskets. I only use metal gaskets nowadays.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 05-29-2015, 05:05 PM   #17
briscuba
briscuba's Avatar
Even though I bought some custom, thick gaskets, I am leaning towards headers being warped. This is making the most sense right now. All of these suggestions are great! My Rochester Carb leaks out gas overnight, I am thinking of going electric. That might take care of the pump situation once and for all.
Thanks.
Old 05-29-2015, 05:26 PM   #18
Fitz
Thanks guys!!
You've got Headers on that truck! Headers are notorious for leaks. A very small exhaust leak can, and often does, sound just like a lifter ticking. If you don't have a long (14-16 inch) screwdriver get a length of 1/4 in iron rod. Use it as a stethoscope at each header tube right at the flange, if one is louder, you just found your "tick".
Fitz is offline   Reply With Quote
Old 05-29-2015, 06:28 PM   #19
Sklptrljay
Sklptrljay's Avatar
Thanks!
No, mine only did it under load. Check out post #12 in this link. It's a video where you can hear the ticking noise I'm talking about.
http://67-72chevytrucks.com/vboard/s....php?p=5935966
Old 05-29-2015, 07:06 PM   #20
leftybass209
leftybass209's Avatar
For sure you need to check this, and rule it out. Also, check your pulleys, fan, and weird things that increase speed with engine rpm. Fuel pump, or rod could be the cause still since you never changed the cam. Best of luck.
leftybass209 is offline   Reply With Quote
Old 06-01-2015, 10:21 PM   #21
Sklptrljay
Sklptrljay's Avatar
Did you ever find that noise?
Old 06-02-2015, 08:44 AM   #22
cdowns
cdowns's Avatar
I'd get a set of the dead soft aluminium or copper exhaust gaskets can b pricy at 30-50dollars but they work better than anything else on the market
