Old 05-29-2015, 01:32 PM   #1
74baggedbug
Brake reservoir
Can anyone Lmk what I could replace my brake reservoir with? Something a lil smaller/cleaner looking.. Previous owner installed this brake system and I'm not sure what he pulled it off of ... Thanks
74baggedbug is offline   Reply With Quote
Old 05-29-2015, 04:27 PM   #2
brown7373
brown7373's Avatar
Re: Brake reservoir
Hard to tell without knowing what year truck and also what brake system. Is it stock or aftermarket?
brown7373 is offline   Reply With Quote
Old 05-29-2015, 04:49 PM   #3
michael bustamante
michael bustamante's Avatar
Re: Brake reservoir
disk or drum front end? i like them v covers
look into wilwood for a small cool looking master cyl
1967custom
michael bustamante is offline   Reply With Quote
Old 05-29-2015, 05:04 PM   #4
geezer#99
geezer#99's Avatar
Re: Brake reservoir
It's from an s10!
http://www.ebay.com/itm/FACTORY-BRAK...-/220594425518
And a stock one like this would work.
http://www.ebay.com/itm/Brake-Master...-/270601475768
And if you want a trick one, call these guys.
http://www.wilwood.com/MasterCylinde...inderKits.aspx
Old 05-29-2015, 05:47 PM   #5
74baggedbug
Re: Brake reservoir
It's disk brakes front and rear.. I'm looking to just swap the reservoir.. Yea just want some nice looking, I think it's the po took of a newer stock system
Old 05-29-2015, 05:53 PM   #6
michael bustamante
Re: Brake reservoir
id look into cpp then or wilwood for a disc disc booster. you might want to look for a newer s-10 because that prop valve is not from our era trucks either
1967custom
Old 05-29-2015, 06:05 PM   #7
leftybass209
leftybass209's Avatar
Re: Brake reservoir
There's a lot of different style master cylinders, you need to decide what your intentions for the braking system are so you know what styles will suit your needs. Whatever you choose, I would suggest staying away from the aftermarket brass proportioning valves. They're usually found under the PV2 model designation. My metering valve just started leaking and upon more research I found it's a common problem, which requires a replacement.
leftybass209 is offline   Reply With Quote
Old 05-29-2015, 08:08 PM   #8
kwmech
Re: Brake reservoir
mid 90s full size truck like maybe a silverado with the 4 wheel discs. Looks like he used the original prop valve though, drum/drum
Old 05-30-2015, 03:04 PM   #9
74baggedbug
Re: Brake reservoir
The brakes work great just want a smaller brake fluid reservoir
Old 05-31-2015, 12:12 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
Re: Brake reservoir
Cheapest route may be to replace it with a CPP Millwood or similar. I wonder if the spacing on the mc is the same for all that use the plastic reservoir? If so, maybe just the reservoir could be replaced...
http://www.rockauto.com/mhttp://ls1t...ed-itself.html
mobilecatalog.php?catalog=314&partnum=18046711&a=www.google.com%2BSearch%2Bfor%2BACDELCO%2B18046711& blanktemplate=true
WIDESIDE72 is offline   Reply With Quote
Old 05-31-2015, 12:13 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
Re: Brake reservoir
Buy a whole new one for the reservoir only.
http://www.ebay.com/itm/M86025-Maste...9259c4&vxp=mtr
Old 05-31-2015, 12:18 PM   #12
WIDESIDE72
WIDESIDE72's Avatar
Re: Brake reservoir
Or there is this
http://www.ebay.com/itm/BRAKES-NEW-G...ecb6ba&vxp=mtr
The only problem with switching the m/c is you may run into issues with the bore size in the booster being different than the mc, or brake line disassembling different.
Old 05-31-2015, 01:22 PM   #13
74baggedbug
Re: Brake reservoir
The mounting heights are different.. I may just have to order a cpp or a wilwood, every time I swap out a part it's a can of worms lol
Old 05-31-2015, 07:25 PM   #14
Keith Seymore
Keith Seymore's Avatar
Re: Brake reservoir
What does the two character sticker on the front of the reservoir say?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-31-2015, 08:30 PM   #15
74baggedbug
Re: Brake reservoir
K
Old 06-01-2015, 08:27 PM   #16
Keith Seymore
Re: Brake reservoir
XD is a GMT800 brake master cylinder part number 18024194, used on:
CK15703
CK15753
CK15903
CK15953
Light duty 2 and 4wd, short and long wheel base, extended and reg cab.
K
1979-1986
1986 - 2019
Old 06-01-2015, 08:35 PM   #17
Keith Seymore
Re: Brake reservoir
1979-1986
1986 - 2019
Old 06-01-2015, 11:02 PM   #18
74baggedbug
Re: Brake reservoir
So I think I have a 1.25 bore, can someone confirm that.. Thanks for all the help, thinking I'm just gonna order a whole new setup
Old 06-04-2015, 10:43 AM   #19
Keith Seymore
Re: Brake reservoir
34mm = 1.34 inches ( so closer to 1 & 11/32 inch).
K
1979-1986
1986 - 2019
Old 06-04-2015, 04:23 PM   #20
74baggedbug
Re: Brake reservoir
K
Dang it I ordered 1" 1/8.. Now I gotta try and see what I'm gonna do to make it work
Old 06-05-2015, 09:34 AM   #21
Keith Seymore
Re: Brake reservoir
I apologize if my delay in responding messed you up.
I was on vacation for a couple days.
K
1979-1986
1986 - 2019
Old 06-05-2015, 12:46 PM   #22
74baggedbug
Re: Brake reservoir
K
Nah no problem, I've been thinking of converting back to Manuel brakes for a cleaner engine bay.. Or I can just send it back and get the bigger 1 ... Thanks for all the help
