Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-29-2015, 01:52 PM   #1
Ont67shortbox
HP/Torque estimate
Engine is at machine shop waiting to be done,I am unanxiously waiting to get it back.With my combo how much power will it make
.030 over 427
10.2-1 pistons
cam is solid roller 252/257 with a .652 lift I/e
Dart Pro 1 heads 310 cc,roller rockers w/stud girdle
121 cc chamber 2.25 I 1.88 ex
Edelbrock Vic Jr intake
Holley 850 df dp
2 inch Hooker headers
Ont67shortbox is offline   Reply With Quote
Old 05-29-2015, 02:29 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: HP/Torque estimate
A whole lot of little things add up,, like is the 10.2 a measured compression given your deck clearance gasket and CH,, or just the advertised from the piston manufacturer.
Wasthe bores finished with a torque plate,, and proper finish for the rings (plasma moly ?) file- fit to minimize gap. Vacuum pump or just breathers...
I've seen pump gas 427's go well north of 555HP,, and I've seen them struggle to make 450. Attention to detail can make that much difference.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-29-2015, 02:34 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
425+
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-29-2015, 05:07 PM   #4
Ont67shortbox
bores were finished with torque,plates,moly rings,10.2 is measured compression with gasket,my last engine had stock 241 casting heads with 2.225/1/88 valves,gasket matched,113 cc heads,had a 246/252 cam with .590/.598 lift solid tappet cam11.5 -1 closed chamber pistons with open chamber heads dual plane and 750 carb,and ran a 12.10 @110 in a 4000 lb truck that figures to about 450 ish,with the larger roller cam and better flowing heads ,single plane and 850 was hoping for 550-600
Old 05-30-2015, 10:34 AM   #5
Marv D
Marv D's Avatar
Do you have a flow sheet for the heads?
With 11.5 compression and iron heads in the old setup you were obviously not running pump 87..... what fuel are you planning to run now?
My opinion (and I'm no big block guy so take this with a grain of salt... may not even be worth that) But at only 10.2:1 compression you are MAXED out on duration. The old engine builders 'rule of thumb' of 250° @ 0.050" for 10:1.... 260 for 11:1 etc was a MINIMUM compression to support the duration.
I would love to see this motor on an engine dyno to see where the torque and peak HP. I bet you have to spin it pretty hard to get the most out of that cam at this compression.
but again just a smallblock guys ramblings.. a big block head responds so totally different
Old 05-31-2015, 09:17 PM   #6
Ont67shortbox
11.5-1 closed chamber pistons with open chamber heads was good for about 10.75 -1 ,I used 4 gallons of 94 with 1 gallon of leaded 110 just because I didn't have hardened seats,the heads are Dart Pro 1 310 cc BNIB so the Dart website should have a flow chart for them.I have a 4.86 gear will spin it to 7000
Old 05-31-2015, 09:39 PM   #7
68c10owner
68c10owner's Avatar
[QUOTE=Marv D;7191448 The old engine builders 'rule of thumb' of 250° @ 0.050" for 10:1.... 260 for 11:1 etc was a MINIMUM compression to support the duration. [/QUOTE]
That use to be the old school way but with modern cam profiles and more custom ground cams being used its not a factor anymore. Compression makes more power but not something to base your camshaft on. The valve timing events can be changed so that a 9:1 engine will make more cylinder pressure than a 10:1 engine. Besides, the camshaft doesnt know what compression the engine has.
I would guess this engine to be in the 525hp range. Did you have the heads flowed? I think those Dart heads are going to want more split on the exhaust valve.
Anthony
68c10owner is offline   Reply With Quote
