Cowl removal: the antenna?
I have the antenna coming up through my cowl piece. Does that stay in place and the cowl come off over it?
Thanks! |
Moderator
![]() Join Date: May 2007
Re: Cowl removal: the antenna?
No, it is attached to the cowl.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Just spin the nut off the antenna base and the mast slips through the bottom of the cowl as you remove it. This is a much easier job w/2 people..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
OK, well great. I hope to do this tomorrow and continue the front clip removal. Thanks.
If it helps unplug the antenna from the radio if ya want and feed the cable out the firewall and pull the whole thing out of the way once you loosen the antenna base.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
It's been a while since I've messed with mine, after removing the nut up top, isn't there two latches that need depressed on the underside to pull it out through from up top? You can then unplug the cable from the antenna.
project: "my happy mess" |
There is a single stamped piece of metal that you have to pivot with a screwdriver or like device, and even then its still a bit of a pain to get it out.
