05-29-2015, 05:25 PM | #1 |
What is this bracket for??
I pulled this bracket off swearing I didn't need to label the bag it was in, it's unique so I should remember where it goes I told myself. Well...... I'm lost. I know it goes on the drivers' side, and it appears to be something for the parking brake, but I'm lost as to where or what it does. I tried lining up the holes on various parts of the frame with no luck. It's from a 69 2wd short bed.
05-29-2015, 05:27 PM | #2 |
BODY SHOP SUPPLIES INC.
Re: What is this bracket for??
auto trans shifter? left side of frame
05-29-2015, 05:41 PM | #3 |
Is that a guess or an answer?
Auto linkage bracket would make sense, the truck originally came with a TH350, and the PO switched it to a 700r4 and never reused this bracket, just hacked some mechanical linkage to work together. |
05-29-2015, 05:42 PM | #4 |
rear end shock mount? for leafs maybe. im just guessing
1967custom |
05-29-2015, 05:53 PM | #5 |
Way off Michael. Like I said I have a relative location, but I need to know the exact function of the bracket so I don't discard it. I appreciate the guesses, but they don't get me the answer.
05-29-2015, 06:11 PM | #6 |
It looks like the bracket on the left of frame that the "relay rod??" Comes across from trans
But yes mostly a guess |
05-29-2015, 07:58 PM | #7 |
Sure looks like the auto linkage support, but it is not year correct. Looks like it is off a later model truck (79-80 ish) that was retro fitted. Anywhere on the frame up by the shifting mechanism that the bolt holes line up on?
05-29-2015, 10:04 PM | #8 |
Born Psycho
X2-Doesn't belong on a 67-72 truck
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-30-2015, 12:51 AM | #9 | ||
http://67-72chevytrucks.com/vboard/s...d.php?t=642401 it appears to be from the 73-87 chevy trucks, for the shift linkage. Thanks again, it fits all my assumptions about where my trans came from. |
