Old 05-29-2015, 06:21 PM   #1
yoshi
yoshi's Avatar
Front too low
Is it possible to raise the front end by 1/2" - 1"? Which has mustangII front clip, if so how? Thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 05-29-2015, 06:41 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Front too low
Donut style coil spring spacer...summit sells em..I don't know about yours but the spacers on my truck are only half as thick as the lift they add... meaning a 1" thick spacer will result in about 2" of lift.
Old 05-29-2015, 06:42 PM   #3
Rude Dude
Rude Dude's Avatar
Re: Front too low
What size springs are you using? They generally came in 4 cylinder springs, 6cylinder springs or v8 cylinder springs meaning each spring is rated larger weight capacity equates to larger springs taller springs higher the car
Rude Dude is offline   Reply With Quote
Old 05-29-2015, 11:06 PM   #4
mr48chev
mr48chev's Avatar
Re: Front too low
How low is "too low"?
I don't remember what you have for suspension, tires or what not.
Lower A arms should be pretty well parallel with the crossmember.
Did you order dropped spindles or ?
Coil spring or coil over?
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 05-30-2015, 08:19 AM   #5
yoshi
yoshi's Avatar
Re: Front too low
Better with a picture, 2 1/2" from cross member to floor
yoshi's 49 project
Old 05-30-2015, 09:19 AM   #6
mr48chev
mr48chev's Avatar
Re: Front too low
Thanks, Stronger springs are in order.
A pair of these would help a little and give a quieter ride but I think you need a bit more than that/
http://www.summitracing.com/parts/hd...FYKUfgodk0oAvA
Here, same brand but 3/4 of and inch thick.
http://www.jegs.com/p/Heidts/Heidts-...95921/10002/-1
Old 05-30-2015, 11:51 AM   #7
_Ogre
_Ogre's Avatar
Re: Front too low
i agree with mr 48
stronger springs will raise the lower arm to level
that's the first true mustII frontend i've seen in a while
shop air compressor timer
Old 05-30-2015, 04:39 PM   #8
yoshi
yoshi's Avatar
Re: Front too low
How much would these raise the front end?
yoshi's 49 project
Old 05-30-2015, 04:52 PM   #9
orngsikL
orngsikL's Avatar
Re: Front too low
you can go to autozone and get spring nuggets. Lol, thats what I call them. They twist in between the coils and lift it up.
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 05-31-2015, 08:57 AM   #10
MIKESAD50
Re: Front too low
change springs
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 05-31-2015, 09:41 AM   #11
solidaxel
solidaxel's Avatar
Re: Front too low
Originally Posted by MIKESAD50 View Post
change springs
YES YES, change the springs!
I had a set of Bobcat A/C car springs and they were to harsh so I went to a smaller wire diameter (lighter) spring and the truck rode better and it did put the front end up a bit higher.
Look around and check out Pinto, Bobcat, Mustang ll for spring rates, coil diameter and height (quantity of coils).
You may have to experiment with a few different kinds until you are happy with the ride and height
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-31-2015, 01:35 PM   #12
Advanced Design
Advanced Design's Avatar
Re: Front too low
I agree with the change spring recommendation. This chart may help.
http://www.eatondetroitspring.com/or...-coil-springs/
Advanced Design is offline   Reply With Quote
Old 05-31-2015, 02:59 PM   #13
yoshi
yoshi's Avatar
Re: Front too low
I think we can assume that mine is an original m2 front clip so I'm thinking I have the same as these on eBay, Item Number381245375359
yoshi's 49 project
Old 05-31-2015, 03:30 PM   #14
solidaxel
solidaxel's Avatar
Re: Front too low
That is a great site, I wish I had seen that 15 years ago when I was dialing in my spring rate, and you can not beat the return reply.
I do not know what the shipping rate is to the UK !
LS 3 4L70E
Old 05-31-2015, 03:48 PM   #15
solidaxel
solidaxel's Avatar
Re: Front too low
Originally Posted by advanced design View Post
i agree with the change spring recommendation. This chart may help.
uk !
LS 3 4L70E
