Old 05-29-2015, 10:51 PM   #1
808turbo
Leaking Floating Hub
Are the bearings in a full float lubricated with grease or gear oil? I have a leak on the inner bearing seal. Gear oil is going from the tube to the hub and leaking into the drums. I removed the axle and found the bearings packed with grease. I don't see a seal between the tube and hub. I'm I missing something?Name:  image.jpg
808turbo is offline   Reply With Quote
Old 05-29-2015, 11:19 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Leaking Floating Hub
The bearings are lubed by gear oil from the differential. It's common to pack the wheel bearings with grease before re-assembly as an added precaution and that's probably why you are seeing grease there now. Do you know what type of rear diff it is? Might be able to find a pic showing just where the seals are located.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-29-2015, 11:30 PM   #3
808turbo
Stocker,
Thanks for the quick reply, its a Dana 60. Looks like I have to remove the big nut and pull the hub off to change the seal? I have never worked on this type of rearend. I just topped off the gear oil last week and changed the pinion seal. I guess it finally made its way out.
Old 05-29-2015, 11:41 PM   #4
kwmech
If you remove the hub, there had better be a seal on the back of it. The grease should not be all that thick, as mentioned it is just a pre-lube type of deal until the oil can travel down the tubes and the diff is topped off. There are actually 2 nuts under the washers
Old 05-29-2015, 11:43 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I've had my Eaton apart a couple times but never a Dana. Just take pics and make notes as you go.... If I run across anything that might help, I'll post to this thread.
- Mike -
RIP El Jay
Old 05-29-2015, 11:44 PM   #6
57taskforce
All about them K’s
57taskforce's Avatar
The seal is on the back side of the hub, probably can't see it till its tore down. It's pretty simple once you get it apart.
Tyler
57taskforce is offline   Reply With Quote
Old 05-29-2015, 11:48 PM   #7
808turbo
Thanks guy,
I guess I know what I'll be doing this weekend!
Old 05-29-2015, 11:52 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Sounds like it's not too tricky but here's a couple threads that might be useful:
http://67-72chevytrucks.com/vboard/s...d.php?t=348884
http://67-72chevytrucks.com/vboard/s...d.php?t=217242
- Mike -
RIP El Jay
Old 05-30-2015, 12:11 AM   #9
SS Tim
SS Tim's Avatar
Its easy enough and the front loading drums make it a bit easier.
Here is a drawing from a GMC manual.
Strongly suggest you have a copy of the service manual for the torque numbers. The 72 is probably your best bet as serveral earlier years do not have clear specs for the Dana 60.
Remember its good practice on full floaters to jack the rear one wheel at a time after refilling the gear oil. This fills the low side hub. Then top off the axle.
RTFM ... Read The Factory Manuals... download 'em here
SS Tim is offline   Reply With Quote
