Old 05-29-2015, 11:32 PM   #1
aod92
aod92's Avatar
Found this inside my door??
Heard something rattling around inside my door and found this at the bottom. What is it?
aod92 is offline   Reply With Quote
Old 05-29-2015, 11:38 PM   #2
kwmech
Re: Found this inside my door??
mirror support backing. At some point somebody took off the factory mirrors and let the bracket fall inside. Wasn't worth retrieving I guess. May be one in the other door as well
Old 05-29-2015, 11:40 PM   #3
aod92
aod92's Avatar
Thanks for the info.
Old 05-29-2015, 11:44 PM   #4
In The Ten Ring
Clean that thing up and save it/use it!
Evaporust
Krud Kutter
Electrolysis
In The Ten Ring is offline   Reply With Quote
Old 05-29-2015, 11:46 PM   #5
aod92
aod92's Avatar
Evaporust
Krud Kutter
Electrolysis
I'll clean it up for sure. Gonna check the other door for a second one too!
Old 05-30-2015, 12:35 AM   #6
In The Ten Ring
If you can (and want), run electrolysis on this bracket for about 20 hours (do outside unless you want your house to explode) then dip it into Evaporust for about a night.
It will look brand new. Hit it with a rust preventer, then prime and paint as desired.
Old 05-30-2015, 08:33 AM   #7
aod92
aod92's Avatar
I'm gonna make it easy on myself and bring it to my buddy's to use his blast cabinet lol
