Putting in a bed tank in the 62 C20 but didn't think of the fuel lines until tonight.
Has anyone used inlinetube.com for this? I've seen it referenced in at least one post but not sure if this is the way I should go. They say the fuel line is just for the 1/2 ton but I figure it should work fine for the 3/4.
1965 C10 Longbed Stepside 1969 Chevelle Malibu 1962 C20 Fleetside - Build Thread (Sold before I could finish) |
![]() Join Date: Sep 2011
Re: Fuel Hard Line for rear mounted tank
I believe that is just for the replacement of the factory portion, but I'm anxious to see responses as I'm getting ready to install my boyd tank.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
It seems like I could buy this from summit - http://m.summitracing.com/parts/sum-220256 but it's coiled and i don't know if I have the skill to get it right nor the tools to do any flaring but I guess I wouldn't need to flare it, just secure the rubber line at each end.
The inline kit is for factory tank.you can buy 6' lengths of stainless 3/8" tubing.i invested in a rigid flaring tool and got a bender from inline.used an fittings.worth the small investment imo.did a bunch of other things as well,fuel pump to carb,pcv etc.will post pics later
#5 | |
Thanks.
![]() Join Date: Sep 2009
i have a fuel pump.filter and fuel line 3/8 and all of the fittings . if someone is interested. was going in my truck but it was sold. pm me for more imfo and pictures if you want
I bought a roll of aluminum tube and ran/built/flared my own. Don't forget to put a vent tube on the tank. Make a 360 degree loop in the vent.
292 + TKO500 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Stainless is definitely the best way to go. But you can also use the straight length of coated steel line found at your local auto parts supplier along with some couplings. You can pickup one of those inexpensive tubing benders at HF as well as many other stores.
