Old 05-30-2015, 09:59 AM   #1
10BamBam01
1972 GMC 400 BB stalling at stop light
Truck runs fine at first few miles. Then the idle will drop too low at a stop light and it will die. I have adjusted timing and set the idle speed higher so that when it goes in gear it will still run. Idle is set to 900 or so in Park and then in Drive it's at 650. When the engine warms up is when the problem starts. It will periodically "sputter" or gasp when going down the street, especially when I just touch the accelerator.
I recently put new HEI dist, new plug wires, checked for vac leaks, checked vac pressure and timing. Can't figure this out. Any ideas?
10BamBam01 is offline   Reply With Quote
Old 05-30-2015, 10:04 AM   #2
hilandr452
hilandr452's Avatar
Re: 1972 GMC 400 BB stalling at stop light
Did you run a new hot wire to the distributor, or are you running off the line with a ballast resistor? That will cut your juice down several volts and ignition will be weak.
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 05-30-2015, 10:38 AM   #3
geezer#99
geezer#99's Avatar
Put some timing in it!
Then turn down that idle. At 900 you're kicking in the mechanical in the dizzy.
Old 05-30-2015, 10:43 AM   #4
68350
68350's Avatar
What's your timing set at?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
