Old 05-30-2015, 06:19 PM   #1
jcblue
jcblue's Avatar
Starter problems..
I'm not sure what I need to do.. Starter gear engages into flywheel far enough but not deep enough into the the teeth of the fly wheel and slips and grinds.. How so I solve this prob.. Have tried shims but not sure if that is helping
jcblue is offline   Reply With Quote
Old 05-30-2015, 07:06 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Starter problems..
have you got a good battery and clean connections ? fully charged ? if so it sounds like the Bendix " starter drive" is going bad you can replace just the Bendix and not the entire starter but usually if the Bendix is going bad the brushes are soon to follow ...
Grumpy old man is offline   Reply With Quote
Old 05-30-2015, 10:31 PM   #3
jcblue
jcblue's Avatar
Might be the battery.. I just snagged one out of another car.. Motor craft at that lol.. The starter is new.
Old 05-30-2015, 11:06 PM   #4
Grumpy old man
new doesn't mean it is a good starter parts made and sold today are junk !
Old 05-30-2015, 11:11 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
There are 2 different size flywheels and 2 different sets of bolt holes for the starter, depending on which flywheel you have. You need to make sure you have everything matched up.....
LockDoc
Leon
Old 05-31-2015, 12:33 AM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I'm confused by "far enough, but not deep enough". Makes it sound like shims may defeat the purpose.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-31-2015, 02:16 AM   #7
jcblue
jcblue's Avatar
I'm sorry I'm not good at explaining myself.. What I'm trying to explain is that the teeth on the starter gear and the teeth on the flywheel are not locking together as deep or tight as they should..
Old 05-31-2015, 02:18 AM   #8
jcblue
jcblue's Avatar
Loc doc. How can I tell what flywheel I have?
Old 05-31-2015, 08:34 AM   #9
LockDoc
LockDoc's Avatar
The two flywheel wheel sizes are 153 tooth, 12.75” diameter. Used on 350ci and smaller engines, and the168 tooth, 14” diameter. Used on small blocks and big blocks, 400ci and larger.
Here is a good post by member "piecesparts":
[QUOTE]There are two sizes of flywheels/flexplates for the GM v-8 motors. There is a 153 tooth size and a 168 tooth size. The starters are designed different for these two sizes. The larger size uses a starter where the bolts are "OFFSET" to each other in the starter housing and on the block mounting pad. The smaller design uses a starter bolt pattern that is straight across from each other.
First take a look at your starter and see which one you have. Second, see if your block has three holes at the starter mounting point. IF you have the smaller flywheel design, then you will need to have the straight pattern on your starter bolts. Third, if it will make you feel better then mark your flywheel and count the teeth on it to see what you truly have.
If you happen to have a small flywheel, three bolt holes for mounting and the starter is an offset pattern, then change starters. If you have a small flywheel and only two holes, then you may have to change the flywheel.
There are aftermarket starters that have both design capabilities and it might be your advantage to purchase on of those, if needed.[/QUOTE
LockDoc
Leon
Old 05-31-2015, 08:53 AM   #10
jcblue
jcblue's Avatar
Thanks for that.. My motor is a 350 but has the offset pattern bolt holes..
Old 05-31-2015, 10:06 AM   #11
LockDoc
LockDoc's Avatar
No problem. Any more questions post 'em up....
LockDoc
Leon
