Old 05-30-2015, 07:00 PM   #1
BC10
BC10's Avatar
Shortbed Stepside bed crossbar question
Hi Everyone,
I took my entire bed off of my 68 Short Stepside two years ago. Now I can't figure how the crossbars are arranged across the frame. The smaller cross bar is the biggest mystery, I just can't figure out how it attaches to the frame since the holes don't match up. Any help is much appreciated.
BC10 is offline   Reply With Quote
Old 05-30-2015, 07:46 PM   #2
SS Tim
SS Tim's Avatar
Re: Shortbed Stepside bed crossbar question
Its a floater and not bolted to the frame.
SS Tim is offline   Reply With Quote
Old 05-30-2015, 07:46 PM   #3
Ruscal
I believe one of the bars floats, and is not needed for hold-down. It does bolt to the bed though. I can't verify that now because my truck is at another location.
Russ
Ruscal is offline   Reply With Quote
Old 05-30-2015, 07:58 PM   #4
SS Tim
SS Tim's Avatar
The factory numbers.
Old 05-30-2015, 08:20 PM   #5
Tim Christian
Tim Christian's Avatar
The small one is a reinforcement strip and does not bolt to the frame at all. Just to the bottom of the bed wood only.
Tim Christian is offline   Reply With Quote
Old 05-31-2015, 12:09 AM   #6
BC10
BC10's Avatar
Wow, thanks for all the help everyone. Does anyone have any info on how the very last crossbar that houses the electrical wires is attached? Does it need to fit between the two main frame bars in the rear, while being welded to the two bedsides?
Old 05-31-2015, 11:50 AM   #7
WIDESIDE72
WIDESIDE72's Avatar
Yes. The ends of rearmost cross member goes inside the bedside and attach with two bolts on each side. Originally they were also welded. I did not re weld mine after reassembly. Just a note regarding painting this cross member; it should be painted body color. On the truck in my profile photos,our painter painted ours black like the other crossmembers. More than likely, No one else notices this but me, but nonetheless...
WIDESIDE72 is offline   Reply With Quote
Old 05-31-2015, 07:06 PM   #8
BC10
BC10's Avatar
Thanks Wideside!
Old 06-01-2015, 10:20 AM   #9
57larry
good information. thanks, I've got my bed off too and don't remember
57larry is offline   Reply With Quote
