Going price for factory tilt column
I've got one secured that will need repainted from factory 67-72 . $160 ,think I'm getting a decent deal ? I'm ok with the price. What do you guys think?
![]() Join Date: Dec 2013
Re: Going price for factory tilt column
I'll take 3 at that price and I only need 2 . Better grab it before someone else does .
Moderator
![]() Join Date: May 2007
Be sure it's from a truck. Even if it's a van tilt, in great shape it's a decent buy if you need it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Last one I saw on the parts board here the seller wanted 300.00 and it came out out of a very rough truck. 160.00 is great deal.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Feb 2008
Sounds to good to be true.
Could be junk. |
Carpe manana
![]() ![]() Join Date: Dec 2010
As a point of comparison, here's one now in good shape listed for $300 plus ship: http://67-72chevytrucks.com/vboard/s...7&postcount=74
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 05-30-2015 at 07:27 PM. Reason: spelling |
Picked mine up restored for 400. I would suggest if you don't already know, to look for signs of it being an actual truck column, and not a van or rv. I don't know how many people at swap meets swear they have truck columns, when in fact, they're not.
And what signs would I look for to tell if it's van or truck?
An rv columns' shift selector at the bottom has 2 90 degree bends in it. The van column has a neutral safety switch located high up on column and the output shaft is noticeably longer than a truck tilt.
![]() Join Date: May 2010
Top to bottom in picture below:
- RV. What looks like a tab sticking out near the shift linkage lever is just the clamp that goes to the engine side of the firewall. - Truck. The firewall/floor seals are pushed up against back of the neutral safety switch in the picture. The van and RV columns also use different seals. - Van Last edited by FirstOwner69; 05-30-2015 at 09:10 PM. |
Here's a link to a FAQ thread regarding how to modify the van columns. I THINK you only have to move the switch on the RV columns.
http://67-72chevytrucks.com/vboard/s...d.php?t=147927 |
Thanks for all replies , too good to be true, it's actually an rv column.
#13 |
Thats ok its still a decent deal at that price.
Scott |
#14 |
The column can still be modified to fit, but I'm glad you were able to figure it out. There's a lot of misrepresentation concerning parts for these trucks, either intentional or not.
#15 |
thanks for the picture ID. I think I bought a van column
#16 |
Van columns shafts can be cut & welded as well, then they are very hard to tell the difference. Then you will still have a collapsible shaft as well.
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 |
#17 |
That is a decent price for a RV column. It is a good way to get a tilt without breaking the bank
#18 | |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
sherm6413 you are good to go, the RV columns that I have seen have the short shaft just like the truck column. Bolt it up and go. Last edited by CaptRMW; 06-02-2015 at 09:40 PM. |
#19 |
Ya I know, I collapsed mine so I could move my column in a couple inches and it was no easy task. Although my collapsible shaft came from a wrecker I had to beat the crap out of it to collapse it.
#20 |
Currently Blazerless
Pulled this column from a 78 Winnabago motor home a few weeks ago, as far as I can tell it's no different than a truck column. It has the straight shift lever, short shaft and cut out for neutral safety switch in the correct location. It does have an odd shaped turn signal lever with built in cruise button tho.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#21 |
Another
#22 |
Odd shaped turn lever
