Old 05-30-2015, 11:40 PM   #1
In The Ten Ring
Now I know I am getting into this truck thing!
That's 20 inches of extensions! *Ha, and I still had 2 more 3/8" extensions to call in......
Used to remove the grill brackets from the outer fenders since I couldn't get the inner grill to come out and had to get the ratchet over to the opening for the radiator.
In The Ten Ring is offline   Reply With Quote
Old 05-31-2015, 09:47 AM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Now I know I am getting into this truck thing!
What, no swivels?
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-31-2015, 09:50 AM   #3
hugger6933
I can see that you have never pull a chevy trans or else you would have a long one like a 36 incher. A swivel really helps in the case of removing the grille when it is time to take out the fender bolt that go in from the inside
hugger6933 is offline   Reply With Quote
Old 05-31-2015, 10:02 AM   #4
In The Ten Ring
I can see you are quite a perceptive guy.
By "swivel" do you mean that linked socket in the set? (A "universal" I have heard it called). I did give that one a go but not with much result. The sagging extension in the pic did work just fine. I'd like to get some 1 piece long extensions for the future.
Old 05-31-2015, 11:16 AM   #5
Acorn
http://buy1.snapon.com/catalog/item....re&dir=catalog
Or even..
Once you have something like this in your tool box, you will wonder how you ever worked without them.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 05-31-2015, 12:22 PM   #6
michael bustamante
michael bustamante's Avatar
Oh yeah wait till you drop an auto tranny. I made a 3 foot extension out of rebarr
1967custom
michael bustamante is offline   Reply With Quote
Old 05-31-2015, 05:27 PM   #7
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Now I know I am getting into this truck thing!
Or even..
AMEN TO THAT. i use my 36 inch extension all the time, 1/2 drive female by 3/8 drive male with a impact wobble socket makes removing trans bolts a piece of cake. i have extensions from 1 inch to 36 inch in 1/4, 3/8, 1/2 and hybrid and it's amazing how ofter they come in handy.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 05-31-2015, 08:10 PM   #8
ho70
ho70's Avatar
you guys bragging about size.........
ho70 is offline   Reply With Quote
Old 05-31-2015, 08:23 PM   #9
swamp rat
swamp rat's Avatar
Originally Posted by RenoKeene View Post
What, no swivels?
ya know your just not a mechanic untill you can do that with a floppy worn out swivel!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-31-2015, 09:07 PM   #10
truckster
truckster's Avatar
Harbor Freight has some decent tools and some real junk, but their ratchet extensions work great and are relatively inexpensive.
truckster is offline   Reply With Quote
Old 06-01-2015, 07:35 AM   #11
hamjet
hamjet's Avatar
Easy fix with a little electrical tape wrapped around the swivel..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 06-01-2015, 08:45 AM   #12
My extensions and sockets are so worn out I don't need swivels
Old 06-01-2015, 02:40 PM   #13
In The Ten Ring
Or even..
So I guess these allow a degree of "play" in using a ratchet? And a greater degree by virtue of the extension length?
Such a thing could have helped, certainly
Thanks guys, I'm learning as I go and buying up more tools as I go as well.
Old 06-01-2015, 02:48 PM   #14
Acorn
Yep. The ball and socket swivel is my favorite. It allows you to rotate the socket smoothly (compared to u-joint style) and works really good with air/power tools. You can find them cheaper at sears or harbor freight etc. Snap-On is expensive. I just happen to have that page up when I read your post.
Old 06-01-2015, 04:39 PM   #15
swamp rat
swamp rat's Avatar
I could go take and post a pic to show you that you are indeed correct.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-01-2015, 05:02 PM   #16
min
min's Avatar
Have changed alot of trannys on chevys (cars and trucks) and never needed an extension. Is this for the newer models?
min is offline   Reply With Quote
