Turn signal switch help
It seems that my blinker switch is in need of some repair.
1965 c10, 3 on the tree all original. Where the blinker lever screws to the inner turn signal cam is cracked right down the middle where the screw goes in and needs replaced. Can the cam itself be taken apart from the rest of the plastic assembly inside or does everything in there need replaced? It just seems that it should come apart at the pivot point. Any input on my problem would be greatly appreciated Thanks, Roy
Opportunity usually comes disguised....As hard work!!! ![]() |
Re: Turn signal switch help
WOW thanks jtrichard, I would've never thought this would be a part store item anymore.
My 64 C10 turn signal lever was very hard to move. I took off the steering wheel and it looked like they had a new part on one side (the part with the little arms to cancel) but they used an older part on the steering wheel. They were not 100% compatible and rubbed so I needed to trim the cylinder shaped part a bit to make the lever work smoothly. I used one of those vibrating cutoff tools from Harbor Freight. Their power tools are not great but that cutter tool has paid for itself over and over.
