Old 05-31-2015, 08:23 PM   #1
Lil Ape
Recommended rear tire size for a stepside?
I have an 83' stepside that's been lowered a little by the previous owner. No flip kit in the rear for right now. And am running factory 235/75/15 on 15x8 wheels currently. Im looking to go wider in the rear and was thinking 275/60/15. Looking to run drag radials mostly for the look, as the truck doesn't get driven often. I like the nitto NT555r's and heard good things about them. The widest they offer is a 325/50/15 which i'm not sure if they will be too wide. Any recommendations on what might work?
And I also plan to swap wheels with what ever tire size i go with. Would 15x8's be a good wheel width for a 275 wide tire? Or if i go larger than that, should I go to a 15x10? Recommended backspacing? I should probably get the backspacing on my current wheels, that may give me a better idea what to run with.
Lil Ape is offline   Reply With Quote
Old 06-01-2015, 10:29 AM   #2
school boy
school boy's Avatar
Re: Recommended rear tire size for a stepside?
Heres mine with 15x8 rallies 4" backspacing and 295-50-15 tires. Truck has a flip kit and 2 inch lowering shackles.
In my opinion, stick with 15x8 wheel with the 275 wide tire or a 15x10 with the 315 wide. Either size tire will fit with correct backspacing.
school boy is offline   Reply With Quote
