saving for some type of square body wich one?
Okay so im 20 years old i just got a job and im saving for my first square i was thinking k10 k5 blazer or k30 crew cab i can do the engine work because my dads a pretty good mechanic im going to try and learn from him i wanted to get a crew cab shorten the frame and put a shortbox on it not sure about the engine possibly a smallblock 400 i have alot of wrecking yards where i live for parts such as tear a part pic n pull sommers etc what would you guys recommend on the specs for this build?
Re: saving for some type of square body wich one?
Come on dude. You are 20 years old and need to use some punctuation.
How do you plan to use this truck?
1982 K10 SWB 1987 V20 - Sold - Doh! |
If its going to be a daily driver that sees traffic skip the 400 they run hot.Unless you need a 4 door pickup go for a standard cab they are a lot easier to park.But like said how will the truck be used?You build a daily driver different then a hardcore off road rig.
Getting Old; Going Broke
For the heartbeat under the hood, thought about a 403? Or a 429? How about a 500? A 425? Heard of a 455?
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
If it were me, I would start with a running, driving vehicle. Figure out what you eventually want, and build towards it. Projects can go sideways and get expensive quickly, if you have a plan it can help keep it on track.
Good luck,
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
Well my dad had a 400 it never really ran hot it was hopped up to where it smoked a 2012 mustang wile the motor was in an 89 k5 blazer im not sure what the gearing was
im just planning on building a blazer for daily driving and hunting and some wheeling im not gonna drop 44s and a 20 inch lift on it and drive through a ****in river, Ill probably put somewhere between a 4 inch lift and 6 inch lift and drop 34s on it
Since your in SLC like me KSL is a good place to start, It seems like everyone around here want's a ton of money for them, took me quite a while before I found mine
#9 | |
When buying an old truck, first think of what you will get when you sell it.
If you don't have much money, then you don't have much choice. The best resale truck is a 1987 (because of TBI fuel injection) and a 6 cyl. is somewhat economical (for an old truck) - see Keith Seymore's truck on this forum. If you are just going for your own transportation, just find a truck with no rust -they do exist, maybe in your neighborhood, but certainly not far away in the desert southwest. Check Craigslist to get an idea on prices. Expect to replace most everything if you want a reliable truck. Most mechanical parts are relatively cheap, but trim parts are expensive and sometimes hard to get. Always get OEM parts if you can, new or used. If your folks will fund you, you are better off finding a semi-restored good truck - probably $4-$7K range. Or, maybe a late model 2000 and up model with modern fuel economy and safety/convenience features. Any $$ you dump into a hopped up/jacked up/slammed truck will likely be lost when you sell it, and it might even lower resale value. (Unless you have a true show truck, which sounds like it is beyond your resources - like $15-$25K.) If you get a truck, check back here before you start dumping $$$ into it. The guys posting know where to get good parts inexpensively and which parts to avoid. Also, there is a lot of troubleshooting and repair knowledge here. Good luck. |
#12 | |
i just dont like the newer body styles and i probably wouldnt resell it for an extremely long time id just keep repairing it maintaining it and driving it |
#13 |
i'm not going to tell you which one to buy, your young & will prob grab the first decent crew or k5 that comes along.
can give you some insight as to how it is living with them on a daily basis though. my '76 K5 had a 400/t350, converted 203 with 3:73's on 35's. nice & maneuverable, easy to park. bouncy on the freeway with the 35's though, poor mileage (8-10mpg). and 400's do run in the upper end of the temp gauge. ok for space till you get married & have dustynova jrs.... personally i like crews, enough space you can live in them...they can haul whatever you can stuff in them, long wheelbase, not a bad ride. b***h to park, they dont turn good. you will end up adopting a different driving style unless you like backing up a lot....their 20 ft plus. p**s-poor fuel mileage, & where i live, i get charged more to go on the ferry than the wife's envoy. not the best type of daily no matter what combo you put in it. daily drove my crew for 6 mons, was all i could literally afford. now it gets used pretty much like a rv.... |
#14 | |
#15 |
Well then the best thought is what are the odds of you having more than 3 people in the truck with you? I personally only have had more than 3 people in my trucks and blazers once most of the time I am traveling with another vehicle and we just split the group up but when I have it was because of a broken down vehicle. So I could easily drive a single cab pickup with a bench seat I even have pulled the back seat out of my current blazer and am putting in a jump seat.
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
#16 |
I have a son your age. He doesn't fair so well with punctuation or the written word either.
Anyway, what you are asking, what you have in mind and what you want to hear are 3 different things. You already know what you want. You ask the question to get confirmation that your idea is wise. And in turn you want to hear that. You are young, have limited finances and want something that will not match your current position in life. Get a long term project that you want and will work on for years to come as long as your finances allow. In the mean time for a dependable daily driver, get a used S10. Good on gas, insurance and maintainence. Just my $0.02... |
#17 |
X2- $$$ and desires often diverge.
![]() When using my 86 C20 454 as a daily driver around town I was getting close to $80-$100 per week in gas alone. |
#18 |
#19 |
I can use punctuation but alot of the times im just lazy.
#20 |
I also rarely leave the house lmao
#21 |
#22 |
#23 |
yeller
Having an old truck isn't for someone who is lazy. They require work, maintenance, money...something you have to be willing to accept and be diligent about. If you are too lazy to punctuate your sentences, you won't be willing to take on the responsibility of an older vehicle...so I'd consider getting a newer car/truck you can turn the key and go.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#24 |
#25 | |
