Old 06-01-2015, 10:06 AM   #1
Jimal
Jimal's Avatar
LMC tranny/transfer case mounts for K10?
How good are they? I think/I'm pretty sure I have a bad tranny or transfer case mount in my truck. I'm getting a lot of driveline movement on decel; the transfer case lever jumps when I come off the throttle, I get an intermittent driveline shudder when I release the clutch from a stand still, and I feel like I'm getting some yaw when I come off the throttle.
I have to assume someone here has used the LMC mounts. Are they any good? I need to order my next batch of stuff, so if they're worth the trouble I'll add them to the list.
Jimal is offline   Reply With Quote
Old 06-01-2015, 11:48 AM   #2
MitchFloyd
MitchFloyd's Avatar
Re: LMC tranny/transfer case mounts for K10?
Assuming your running the T221 transfer case.
I used the LMC rubber mounts. they were the same as OEM. If you don't want the rubber ones you can use the Poly ones at summit.
http://www.summitracing.com/search/p...del/k10-pickup
shouldn't have a problem with either ones.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 06-01-2015, 03:45 PM   #3
Jimal
Jimal's Avatar
I think I'll go the Energy Suspension route. Thanks for the tip.
Old 06-01-2015, 03:49 PM   #4
Jimal
Jimal's Avatar
That is a good question. Off the top of my head I don't know which transfer case I have. All I know is it is divorced and behind a 4-speed.
Old 06-08-2015, 07:53 PM   #5
Jimal
Jimal's Avatar
I finally got around to poking around underneath the truck to see what is going on with the transfer case.
It seems like it is rotated counterclockwise in this picture, with the top leaning toward the back of the truck.
I think I found the culprit. Assuming that the bushing linked above, Energy Suspension 3.1107G, are correct for this transfer case, it SEEMS like replacing them should be relatively easy, and will address the movement I've been experiencing.
Old 06-08-2015, 08:14 PM   #6
padresag
also check for side and end play on the shafts. may be time for new bearings
ron
padresag is offline   Reply With Quote
