Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-01-2015, 10:50 AM   #1
monte0185
monte0185's Avatar
Vacuum Issues
I just got a pro street truck and noticed its got a leaky rear main seal. My guess is its got some pressure inside the engine pushing it out and the cams to big for any decent vacuum. Back in my Drag racing days we just run the moroso crankcase evac system off the headers but this has mufflers so I dont think thatll work. what about a vacuum pump? Its got a rigged up manual brakes on it now I plan on going to a hydroboost setup for that but still need something for a PCV system. Ideas please and pics would be great as well.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 06-01-2015, 05:29 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Vacuum Issues
I've ran the header evac kits on the street motors with mufflers. A pretty freeflowing exhaust system tho (3" through 3" mufflers then turndown at the rear end) It certainly worked better than nothing. I'm about to put a (well used) Aerospace vacuum pump on the street but I honestly think longevity is going to be an issue.
I guess question is,, your carb has no provision for a PCV?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-01-2015, 07:17 PM   #3
cableguy0
Re: Vacuum Issues
If its pulling enough vacuum for even rigged up brakes a pcv should work. 8-10 inches of vacuum should be fine. I agree with Marv though I doubt a vacuum pump will last any huge length of time on the street and they aren't exactly cheap to be replacing often.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-02-2015, 10:19 AM   #4
monte0185
monte0185's Avatar
Re: Vacuum Issues
It appears I do have a pcv valve it was hidden in the pass side behind the spark plug wires. Im going to try to find one of the low vacuum PCV valves and replace it cause I dont think its working well. Or i just need to replace the rear main seal. Guess well see.
Cheapest I found that may work was like 100$. Right now Im running manual brakes and although they work decent Im swapping to Hydroboost. I have a setup on a parts truck im gonna rob. LOL
Old 06-02-2015, 11:29 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Vacuum Issues
I made the jump to HB due to the cam on my LQ4. Going from manual to HB is a shock, since the pedal feel is so drastically different, and the raw clamping force of the brakes is about 2.5x what you'll ever put out by foot.
I've never had an issue pulling enough vac for my PCV system, but I will be adding a catch can just to prevent the little bit of oil that could make its way into the intake.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-02-2015, 01:34 PM   #6
monte0185
monte0185's Avatar
Re: Vacuum Issues
I have HB on my dually so shouldnt be too much of a shock to my system. LOL Here are my toys..
Old 06-02-2015, 05:51 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Vacuum Issues
Your tow rig is pretty much what I'm hoping to find. A fairly clean CC DRW.
Old 06-02-2015, 11:54 PM   #8
cableguy0
Re: Vacuum Issues
Do you have a breather on the opposite valve cover from the pcv? Also is the rear main the only thing leaking. Generally excessive crank case pressure will pretty much push oil out from everywhere. I would be suspect of a bad rear main especially if its a 2 piece seal.
Old 06-15-2015, 04:42 AM   #9
Rannos
Rannos's Avatar
Re: Vacuum Issues
This is very true. The sbc in my truck now is set up for a good bit of nitrous and my machinist suggested I run a vacuum pump. The truck is street driven so I did not use one. It blows oil out EVERYWHERE except the rear main seal. I've tried PCV's and they didn't help (I didn't try a low vacuum one tho). Seems to do best with free flowing breathers and limited baffles but the breathers get oil soaked fast. I am planning to use one of the electric vacuum pumps off the old caddy's to try and sort it out.
Rannos is offline   Reply With Quote
