06-01-2015, 12:27 PM | #1 |
Axles
Hi all. My first post here. Great site and lots of helpful folks with good info.
So, hoping somebody here can help with an issue I have with axles for a 68. I recently got 71 axles so I can convert to 5 bolt, but noticed that the axle shafts are longer than the 68 ones. Can they be used? or do i need to get another set? Additionally I will be changing our the brakes to disks with an adapter plate. Thanks |
06-02-2015, 09:31 AM | #2 |
Re: Axles
Apparently this is going to be a problem.
06-02-2015, 11:26 AM | #3 |
Re: Axles
As you can see they are longer starting somewhere from the end of 70 on up. you could get the 6 lug axles drilled for 5 lug. might be cheaper than finding new axles..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 06-02-2015 at 02:56 PM. |
06-02-2015, 12:02 PM | #4 |
Re: Axles
Thanks HamJet. Looking for a solution now. I see them list in places on line for "C10's" but no mention of the length. I surely dont want to buy another set.
06-02-2015, 12:04 PM | #5 |
Re: Axles
Several companies make 5 lug axles to fit your housing about any vendor selling parts for our trucks can have them. Welcome to the site. Jim
06-02-2015, 12:08 PM | #6 |
Re: Axles
Thanks Jim. Looks like I might just get CPP axles and be done with it.
Oh and here is my project..... |
06-02-2015, 12:09 PM | #7 |
Re: Axles
Those appear to be used axles?
If you can get the 71-72 housing they came out of, the 71-72 housing will bolt right in to your truck.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
06-03-2015, 11:31 AM | #8 |
Re: Axles
Anybody know if a 73 will bolt up?
06-03-2015, 12:12 PM | #9 | |
Re: Axles
You can't run them as they are; bearings will not fit. Send them to Currie in socal. they can shorten them (for a fee) or ask the seller to replace them with proper length 5 lug axles or just take them back and give you a refund. There are many places you can get proper length 5 lug axles for your diff. Strange Engineering, Currie Enterprises, Mosher Engineering or Early Classics Enterprises. |
06-03-2015, 03:29 PM | #10 |
Re: Axles
An option is to contact Captainfab, He makes disc brake kits he may have the spacer to use those axle shafts with the shorter housing. not sure but you could ask him. he may have a kit for 5 lug and disc brakes. Because I think with a longer axle shaft meant less back space for the caliper mount...all he can say is no. Just a thought.
Welcome to the board. Scott http://67-72chevytrucks.com/vboard/s...d.php?t=398352
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
