Old 06-01-2015, 05:15 PM   #1
par4tom
Temperature Gauge Wiring Using Stock Gauge
Good afternoon...
I have a 1961 Chevy truck (v8) with the stock temperature guage in the cluster. So instead of using an aftermarket gauge, I tried to bring this gauge back to life.
I purchased the correct sending unit and installed it, but when I went to hook up the lead to the sending unit I noticed that there was no voltage being fed to the sending unit.
So you know, I had previously abandoned the stock firewall connecting plug and tried to tap into the dark green, cutting the green wire on the back of the gauge and feeding that directly into the sending unit. Unfortunately, this didn't work and in hindsight I can probably see why.
Can someone share with me exactly where this gauge will pick up it's source voltage? Maybe instead of cutting and splicing into the green wire, I should have just tapped into the wire at the back of the gauge using one of those "pacman" taps???
Also, does the pink wire on the back of the temp gauge just go to ground? It looks like it does...
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 06-01-2015, 06:40 PM   #2
pimpston65
pimpston65's Avatar
Re: Temperature Gauge Wiring Using Stock Gauge
heres a pic of my cluster with gauges and oem sensor.
pimpston65 is offline   Reply With Quote
Old 06-01-2015, 06:54 PM   #3
par4tom
That sender looks like mine, and the green and pink wires on the gauge. Does the lead from the sender go into the green wire?
My Build Thread
Old 06-01-2015, 07:02 PM   #4
pimpston65
pimpston65's Avatar
no the green wire to the sensor is light green it flows through the harness then out to the sensor
Old 06-01-2015, 07:03 PM   #5
pimpston65
pimpston65's Avatar
it will got through my build book to show routing in a bit!!!
Old 06-01-2015, 07:56 PM   #6
pimpston65
pimpston65's Avatar
lets see if you can follow this road map!!!
Old 06-01-2015, 07:58 PM   #7
pimpston65
pimpston65's Avatar
should be easy, i hope...
Old 06-01-2015, 08:42 PM   #8
par4tom
I got it... That lead from the sender is picking up voltage through the input side of the gauge, I had it backward!
Thank you very much for your help!!!
Tom
My Build Thread
Old 06-01-2015, 09:08 PM   #9
pimpston65
pimpston65's Avatar
Tom
Glad you found your way!!!
