Old 06-01-2015, 07:13 PM   #1
OldChevy61
OldChevy61's Avatar
62 engine swap
Going from 235 to 350. I have the factory v8 bell housing, the 72 engine stands. What else do I need to do a mock up to get the stands in the right place. Motor mounts from a 72? Pulling the 6 out tomorrow and want to get the engine stands in place before I send the block to the machine shop.
OldChevy61 is offline   Reply With Quote
Old 06-01-2015, 08:46 PM   #2
62 Barnfind
62 Barnfind's Avatar
Re: 62 engine swap
I have been thinking about doing the same to my 62. I found the V8 bell housing and I also found the front u engine mount. These things are getting hard to find. Lucky I located two for a good price. After some research I think I would want to go with the original mount in the front to keep the originality. Your bell housing have the hydro clutch mount?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 06-01-2015, 08:55 PM   #3
OldChevy61
OldChevy61's Avatar
Re: 62 engine swap
Yes sir, hydraulic on passenger side. Already have the 72 stands.
Old 06-01-2015, 09:14 PM   #4
62 Barnfind
Re: 62 engine swap
Cool! I'm still on the fence on doing the swap. I want the power but I also want the original look. Good luck on your swap!
John Z
62 Barnfind
Old 06-02-2015, 09:05 PM   #5
OldChevy61
OldChevy61's Avatar
Re: 62 engine swap
Got the motor mounts figured out,so now to the next hurdle. Headers. Wanted to go long tube,but seems nobody makes one that works with the torsion bar suspension. Someone suggested clippsters. After reading up on those,it says you have to run some autolite shorty spark plug. Not in my truck,lol. AC delco plugs for me. So then I looked at block huggers. Will these work since I'm using 72 motor mounts? I don't like them,to much like stock manifolds. I'm nowhere close to that point yet,just trying to plan ahead. As I stand and look at the truck with no motor,it just seems as though the long tubes would go right under the torsion keys. I just hate to buy something that want work. Of course I have a BFH if something needs modification.lol
Old 06-02-2015, 10:29 PM   #6
LVPhotos
LVPhotos's Avatar
Re: 62 engine swap
Little on high side but other options available.
http://www.speedwaymotors.com/Search?query=ram%20horn
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-03-2015, 01:02 AM   #7
Vincenthdfan
Re: 62 engine swap
Yeah, I'm trying to decide whether to buy a set of the Ram Horn Headers or stay with my original Ram Horn Manifolds off of my 283 on my '62 SWB.
I'm in the middle of installing a brand new crate motor right now.
Vincenthdfan is offline   Reply With Quote
Old 06-06-2015, 05:38 PM   #8
OldChevy61
OldChevy61's Avatar
Re: 62 engine swap
Does anybody have pics of the hedman 69260 headers installed on a 60 to 66 truck. Says they want fit torsion bar system, but would like to see just how they do fit on the other trucks.Maybe a little fab work is all they need. 62 ,running 350, factory v8 bell w/hydraulic on passenger side. Need to know if they run under the bell cross member or over. Pics of header looks like they would run under.
Old 06-06-2015, 06:08 PM   #9
LVPhotos
LVPhotos's Avatar
Re: 62 engine swap
Will not clear clutch fork. Mine are Hookers but same issues.
Old 06-06-2015, 07:20 PM   #10
OldChevy61
OldChevy61's Avatar
Re: 62 engine swap
The Headman,s are long tube and pics look like they run straight down Infront and under the bell cross member. If that is the case,should clear everything. If not, my Son may get to test his fabricating skills. Really want long tubes.
Old 06-06-2015, 08:38 PM   #11
LVPhotos
LVPhotos's Avatar
Re: 62 engine swap
Just saying that fork sticks out 2" more.
Old 06-06-2015, 09:00 PM   #12
OldChevy61
OldChevy61's Avatar
Re: 62 engine swap
Will the hydraulic bearing work off the stock master cylinder? Looks expensive,lol.
Old 06-06-2015, 09:14 PM   #13
LVPhotos
LVPhotos's Avatar
Re: 62 engine swap
Yes, yes, $400, after the bone I got its going to be right.
Old 06-07-2015, 12:03 AM   #14
Captainfab
60-66 Nut
Re: 62 engine swap
Here are some pics of the Hedman 69260's on a '63-'66. These were on a members truck that he has since sold.
Old 06-07-2015, 07:55 AM   #15
OldChevy61
OldChevy61's Avatar
Re: 62 engine swap
Thanks Captrain, Driver side definitely exits below cross member. If anybody has a pic of passenger side undertneath with the factory bell cross member, I would appreciate it. The more I look at the last pic,it does appear to exit below. And I see nothing that would interfere with torsion bars.
Old 06-08-2015, 12:01 AM   #16
Captainfab
60-66 Nut
Re: 62 engine swap
Each side of the Hedman 69260's are mirror images of each other.
