06-02-2015, 06:53 AM | #1 |
62 burb maiden towing voyage
Load leveler rear bags installed, 15x8 rear rims with more meat installed. Brake booster / bracket and vette m/c installed.. 700r4 installed. Brake controller and hitch installed. Much thanks to some of you on this site for parts!
Posted via Mobile Device |
06-02-2015, 07:07 AM | #2 |
06-02-2015, 08:26 AM | #3 |
Re: 62 burb maiden towing voyage
neck was killing me so I had to help =0)
dont want to hear excuses, i want to hear solution(s) |
06-02-2015, 09:06 AM | #4 |
06-02-2015, 09:54 AM | #5 |
Nice Burb. I want the Willys!!!!!!
Could you tow it to my house? |
06-02-2015, 11:44 AM | #6 |
06-02-2015, 11:56 AM | #7 |
Very Cool! Funny how big the Willys looks on the trailer. Makes the Burb look small.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
06-02-2015, 04:33 PM | #8 |
Chevy addict
What size are your wheels and tires on the Suburban?
Hot Willys, be worth the shipping fee. |
06-04-2015, 11:20 AM | #9 | |
The tires on them are all Prodigy H/T P235/74R15. All 4 tires are new but one found the sharp point of inner fender bolt when previous owner lowered front end a bit too far. So it has a defined cut all the way around the circumference but does not appear to be deep enough to cause a problem. Needless to say I quickly removed that fender bolt and keep more tension on front torsion bars Posted via Mobile Device |
06-04-2015, 11:21 AM | #10 | |
06-04-2015, 11:35 PM | #11 |
Chevy addict
I was thinking about using 235/70r15 in the front on 7" rims and 255/70r15 in the back on 8" rims. I like the tire size on your Suburban, it's got me thinking. Thanks.
06-06-2015, 10:50 AM | #12 |
Hey Tom, What rear springs are you running besides the load leveler bags? I love the stance of your 'Burban.
06-06-2015, 04:48 PM | #13 | |
Rear springs a little soft but the leveler bags really ad some ride adjustment. Especially when towing. Posted via Mobile Device |
06-21-2015, 11:47 PM | #14 |
Tom can you give some details on what you used for load leveling bags. I have a 'burb with a similar static drop and would like to tow.
Scottie |
06-22-2015, 05:43 AM | #15 | |
I went with Performance Online's load leveler product . P/n RAA6072. Just under $300 with shipping. Nice product but in my case I had to modify the upper brackets. They interfered with tire buldge and would not work out of box. I took a picture during install and will try to post here showing the problem. About 3/4 inch off. Solution fairly easy, drill new holes 3/4 inch inboard and trim outboard edge of bracket same amount. Maybe they work fine on a pickup out of box? but no way in the burb without modifying. Easy to do tho. Like the product so far. Good luck. Posted via Mobile Device |
06-22-2015, 09:05 AM | #16 |
Nice, thanks! Since I have a 62 chassis under my 64 body, will probably have the same clearance problems. Great to know! - Scottie
06-27-2015, 04:44 PM | #17 |
Hi Tom, nice Burb. It's good to see another one in the area.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
