06-02-2015, 08:57 AM | #1 |
Craigslist find Central Idaho
This seems like a pretty decent ruck. Might have to see if I can trade my 66 for it.
http://spokane.craigslist.org/cto/5016250538.html
66 shorty |
06-02-2015, 09:06 AM | #2 |
Re: Craigslist find Central Idaho
Wow is that truck short. Looks like he cut more than 12" out of the front of the bed.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
06-02-2015, 09:30 AM | #3 |
The Older Generation
Looks like the 12" and the 8" were both cut from the middle instead of 12" from the middle and 8" from the rear. It is a nice truck except for that..... Just my 2¢ worth LockDoc
06-02-2015, 09:46 AM | #4 |
Doesn't look all that bad, but why on earth does it have two alternators? newer bracket style on the lh side and era correct bracket on the rh side. Maybe one is just a dummy and used as an idler pulley in order to make other things work out I suppose. Can't really say I've ever seen that before though.
06-02-2015, 09:46 AM | #5 |
Go Pack Go!
I bet he put that body on a blazer frame.
06-02-2015, 11:30 AM | #6 |
OMGosh.....what a snub tail!
I like short trucks like women like short......um....men. |
06-02-2015, 12:08 PM | #7 |
Look past the goofy bed and think for a second.....Could that be a 50th Ann. cab ? As soon as I saw the firewall i was curious. Somebody needs to go check that out.
06-02-2015, 12:24 PM | #8 |
The short wheelbase is great for rock crawling but leaving so much bed after the rear axle makes me wonder if it will get hung up on the departure angle unless he was thinking of installing huge tires. It also could be the sharp angles at which the photos were taken. Craigslist photos are usually bad.
The 2 alternators are probably to power a winch or an on-trail welding set-up without hitting the batteries too hard.
1971 Cheyenne Big Block Longhorn |
06-02-2015, 12:26 PM | #9 |
Member #1049
06-02-2015, 01:04 PM | #10 |
One of the First
x3
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
06-02-2015, 08:52 PM | #11 |
Now that I look at it closer I see what everyone is talking about. Too much of a mishmash for me.
66 shorty |
06-02-2015, 09:00 PM | #12 |
I think the back portion is short bed length, it just looks longer since the front part of the bed has extra missing. The repaint appears to have been done over dents and all as well, and as shown in the one picture of the door frame it's not a great paint job.
All of that being said they are only asking $5,000. That doesn't look like a bad deal.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-02-2015, 10:11 PM | #13 |
Born Psycho
it says it has power steering but i don't see a pump? still looks like an o.k. truck.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
06-03-2015, 10:16 AM | #14 |
06-03-2015, 10:22 AM | #15 |
With the rusted cab corners and needing to shorten the bed, I would have made a unibody out of it. Bring the bed sides all the way to the door jambs would solve both issues and make a cool custom out of it.
06-04-2015, 01:00 PM | #16 |
My thoughts exactly
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
