Old 06-02-2015, 05:52 PM   #1
davepl
davepl's Avatar
Panic! Did I spend $600 on the wrong column?
[Later edit - just for context, it turns out to be the correct column; photo added in later post]
My original on the right, the one I purchased from a forum member (who restores them) on the left.
As you can see it's quite different; it lacks the detent plate for the automatic transmission, among other things.
Am I hooped here? Did I get sold a three-on-the-tree column? I can't imagine tilt columns and standard transmissions were common together...
Please advise, as you can imagine, I'm stressed. I don't think they even made 3-speed tilt columns, but I can't imagine how this will provide reverse lockout and so on. To be clear, the top end is automatic (shift indicator, all of that).
I'm using a 200-4R trans, so perhaps he removed them because they'd be "wrong" for the shift positions on the detent plate? And so I rely on the ones in the transmission? But that doesn't lock out reverse, etc.
Thanks!
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-02-2015, 06:39 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Panic! Did I spend $600 on the wrong column?
No pics showing but the non tilt has the detents down low, outside the firewall, and the tilts have the detents up high in the column. I'm guessing that is what you are comparing.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 06-02-2015, 08:46 PM   #3
FirstOwner69
FirstOwner69's Avatar
Without a picture, it's hard to tell, but the tilts do not have a detent plate. Don't know what you mean by "...among other things...". I posted a picture of the 3 tilts that will work in our trucks in post 10 of this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=672309
Mine works great with my TH400. Not sure if the 200-4R requires anything different.
Jim
FirstOwner69 is offline   Reply With Quote
Old 06-02-2015, 08:58 PM   #4
71swb4x4
71swb4x4's Avatar
Call the guy you bought the tilt from. He knows them inside/out, quite literally. He will tell you exactly what is going on.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-02-2015, 09:25 PM   #5
davepl
davepl's Avatar
I already reached out, and he got back to me assuring me it's fine. There don't seem to be any detents in the column, though, as it rotates freely. I think the trans has them internally, but I'm not sure how the column's end works. Perhaps the shifter handle must be installed for that, and I haven't done so yet.
So, it looks like all is well.
Old 06-02-2015, 09:31 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Your pic well illustrates the difference between the ends of a tilt (left) and non-tilt (right) column.
Old 06-02-2015, 09:35 PM   #7
davepl
davepl's Avatar
Adding the shifter handle (had to harvest my old roll pin, but he may have supplied one) did indeed make the detents work. Of course I wanted to make sure I had the right column before I installed all of the pieces!
It's a little gritty, perhaps media blasted, but otherwise smooth and tight!
Old 06-02-2015, 09:37 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Enjoy your new tilt column!
