06-02-2015, 08:36 PM | #1 |
break-in overheating, Help
just searched some old threads but wondering if you guys could come up with other ideas or point me in right direction
heres what i have: new basic gm crate 350 comp262 cam with 981 springs duel electric fans 180 themostat that I drilled two small hole in and bench tested ! I manually am turning on fans before I start up! now trying to break in cam but as I get to 5min or so it overheats seems like i'm getting flow in radiator radiator tanks are hot, but I get hold my hand on front of radiator lower hose is hot but I can touch top hose is hotter than hell and very firm I'm leaning towards air trapped in system but feel like I should have got it out by now gonna try running without thermo tomorrow any other advice would be nice, I can't wait to drive it!!! |
06-02-2015, 08:50 PM | #2 |
Re: break-in overheating, Help
Air in the system. Take your thermostat out and fill from there, leave the radiator cap off as well.
71 c10 350 sm465 - sold 71 c10 305/th350 - dd |
06-02-2015, 09:58 PM | #3 |
Overheats as in the gauge says it's really hot or does it boil over? Just a reminder that the stock radiators without an overflow tank are to be filled only to about 3" below where the cap seals.
06-02-2015, 10:06 PM | #4 |
Definitely overheating, only had light go off once and that's when I pushed it trying to get the air out that I still think I have.
Just finished taking thermostat out and will leave level down a bit Gonna try tomorrow |
06-02-2015, 10:21 PM | #5 |
Old school heads or Vortec? A/C? Where's the temperature sensor? Is it your original? Sounds like you don't have a gauge dash, and you are basing the overheat condition based on a warning light Correct?
06-02-2015, 10:38 PM | #6 |
Just curious how long did you run it for after it exceeded 180? As soon as mine hit about 210 we shut it down and just tried to purge the air by squeezing the radiator hoses, fired it back up and it went to roughly 215 a few nervous seconds and then shot back down to a steady 180.
Scott |
06-02-2015, 10:52 PM | #7 |
No a/c, old school heads, temp light only, with new sensor. Saw light once and was shutting it down as I saw it so not long. It's an overheat and not a sensor, I have lots of steam and scorching hot radiator fluid.
06-02-2015, 10:58 PM | #8 |
Got initial timing set w/ a light?
06-02-2015, 11:10 PM | #9 |
Yeh. Set at +11
Plugs at .045 Starts and runs great |
06-02-2015, 11:38 PM | #10 |
Double check timing and air in system. Do you have your heater hoses hooked up? It would be really good if you could get a test gauge so you can see exactly what the temp is and if your t stat is opening.
Really dumb question but, are the fans blowing the correct way? (I ask because I've put one on backward once!) do they have a shroud? Do they feel like they are blowing good? Be extra careful to not overheat a new eng. you could collapse your rings....
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
06-03-2015, 05:12 PM | #11 |
Yeah fans are correct.
ran it today and also did a radiator flush. It works well with no thermostat and didn't get nearly as hot so finished the cam break in and did the recommend ring break in even though it says its not necessary. I have the oil draining now. still seems a bit warm which good just be the 'new' motor or my radiator isn't flowing that great even though it doesnt look that old, but I have no clue what the temp really is so I'm shopping for some aftermarket gauges to go under dash. Any recommendations on what you like or dislike? thanks again guys for your ideas |
06-03-2015, 05:23 PM | #12 |
For my camaro I just went to O'Reillys and grabbed a 3 guage pod. Alt, temp, and oil pressure. 50 bucks or so and its a breeze to put in. Guages are autometer. A brand new fresh motor will probably run a lil warmer than normal just because all the tolerances are tight. Once it breaks in should run normal temp. What degree thermostat did you put in?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
06-03-2015, 05:25 PM | #13 |
Wtf now ?!
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
06-03-2015, 05:26 PM | #14 |
SIX times signed in , post vanished...
11+ ° BTDC is a LOT of advance in the timing unless the CR is like 6.5:1
06-03-2015, 05:32 PM | #15 |
I left the thermo out for now, debating on a 160 or 180 when I'm ready. probably run to autozone tomorrow for cheap cluster
Timing will be checked again soon, I need to adjust carb, choke, and kick down cable too. It seemed good at 11 but I know most guys run around 8 right |
06-03-2015, 05:33 PM | #16 |
Correct .
06-03-2015, 07:19 PM | #17 | ||
"I ain't nobody, dork."
11 degrees advance is not a lot of advance timing. Even for a stock engine. With the 262 cam even 14 degrees advance will be good. Is it the old original balancer? Is the timing mark on the balancer correct? If you have timing too far retarded it will run hot. It can run so hot it will make the exhaust manifolds glow orange.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-03-2015, 07:33 PM | #18 |
X2!!
I run 14 initial with a stock 305. Have run 22 with an 11 to 1 aluminum headed motor. Running well below optimum timing is like pouring one gallon of gas on the ground when you put 10 in the tank. |
06-03-2015, 09:42 PM | #19 |
Well I'm definitely not an expert on timing. Had my friend who has lots of experience set it and I trust him. Although we will check again. It's was a new balancer which was put on by machine shop that installed cam. Will know more once I get temp gauge hooked up.
06-03-2015, 10:10 PM | #20 | ||
Timing with a timing light? Or winging it?
Gary
06-03-2015, 10:15 PM | #21 |
are you using a good break in oil to start ?
06-03-2015, 10:32 PM | #22 |
With a light
Used brad penn break in green oil |
06-18-2015, 08:58 PM | #23 |
Just wanted to update this in case anyone else has a problem in the future.
Turns out it was the radiator. My "old" one looked good, inside and out, but I suspected some flow issues and I finally caved in and bought a cheap a369 from autozone, now it's right at 180*. Thanks again for all the suggestions |
06-18-2015, 11:11 PM | #24 |
Glad you finally got it going. I hate when crap like that happens.
You wonder if you spent all that money and time for nothing. Really creates some serious pucker factor in your BVDs.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
06-19-2015, 08:26 AM | #25 |
Before tossing the old radiator , give it a citric acid flush , that cleans better than anything else I've ever used .
