Old 06-02-2015, 10:17 PM   #1
Ricos54
Ricos54's Avatar
Wiring Harness for my 54
What is the best and easiest wiring harness to install in my truck. It is a street rod so it will have all the modern updates, electric windows, stereo, a/c, led's inside and out, etc,,,
Ricos54 is offline   Reply With Quote
Old 06-03-2015, 05:54 AM   #2
shrek55
Re: Wiring Harness for my 54
Using 21 circuit EZ Wire in my 55 1st series
shrek55 is offline   Reply With Quote
Old 06-03-2015, 09:39 AM   #3
Jurassic-1
Jurassic-1's Avatar
I used American Auto wire and had no problem with it. Clearly marked and an assortment of options.
Jurassic-1 is offline   Reply With Quote
Old 06-03-2015, 12:06 PM   #4
OrrieG
OrrieG's Avatar
EZ wire 21 here too. right size wires, labeled every 6 inches. pretty good instructions and I always got the owner on the phone for questions I had. Even with the kit I still purchased another $250 in looms, connectors, additional relays, switches, etc. I am glad I did not buy a kit with the end connections made up I ended up shortening just about every loose wire in the kit. comes set up for standard GM columns, dimmer, and ignition switch. Lots of detail on the install in my build thread. There is also a guy named Horvath (google it) that has details on his AD install and lots of good information and links.
OrrieG is offline   Reply With Quote
Old 06-03-2015, 11:20 PM   #5
_Ogre
_Ogre's Avatar
same here
never heard of that horvath guy
he use to hang out on the forums, must have his truck done
shop air compressor timer
Old 06-04-2015, 12:40 AM   #6
OrrieG
OrrieG's Avatar
Don't think he was ever a member, I stumbled across his site researching relays. http://www.alanhorvath.com/54chevy/index.php#
