06-03-2015, 10:54 PM | #1 |
Strange air bag issue
Anyone ever have an air bag that keeps filling with air slowly after you quit pushing the button to fill the bag? I'm guessing the fill valve is sticking. My valves are big red from ride tech. Anyone had a similar issue? I figured that I would try here before calling ride tech.
Thanks Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
06-03-2015, 11:57 PM | #2 |
Re: Strange air bag issue
I had the opposite with the same valves. You would air down and it would stick open. If you hit the switch a few times it would close. Sold the truck before I ever fixed it.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-04-2015, 01:11 AM | #3 |
Try rocking the switch back and forth a few times,If theres dirt or something in the valve that should knock it loose.
06-04-2015, 09:04 AM | #4 | |
Thanks Marc
06-04-2015, 11:37 AM | #5 |
Most of the time popping the valve back and forth will fix a slow leak,If that don't work then you gotta take them apart to see what's the problem.If you ever do need to take them apart http://www.ridetech.com/info/solenoid-valve-service/
