Old 06-04-2015, 08:43 PM   #1
jerry1194
65 gmc fatman suspension
First of all I am not a mechanic but love working on my truck.I want a modern front suspension on my truck.My question is,is a Fatman front suspension a good value and a good set up for my truck(1965 GMC short bed,fleetside)?Is there better set ups that are a good value out there.I would appreciate any feed back. Thanks Jerry
jerry1194 is offline   Reply With Quote
Old 06-05-2015, 05:35 AM   #2
andrewmp6
Re: 65 gmc fatman suspension
Honestly i would skip the aftermarket stuff,You can bolt in the whole front suspension from a 73-87 c10 if you drill two holes,And no limit has a rack and pinion kit if you want one.If i had to go aftermarket i would go no limit or scotts hot rods both are forum vendors.
andrewmp6 is offline   Reply With Quote
Old 06-05-2015, 06:28 AM   #3
PGSigns
PGSigns's Avatar
There is the make it handle thread to go through that has a ton of info on this subject.
I have done a lot of the updates and little things to improve the ride and handling and it is fun to drive. Is yours truck arms or leaf springs in the back?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-05-2015, 07:30 AM   #4
jerry1194
It does have leaf springs.
Old 06-05-2015, 12:20 PM   #5
Scottshotrods
Take a look here www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 06-05-2015, 03:10 PM   #6
jerry1194
I just talked with Justin at Scotts Hot Rods and decided to go with them,just waiting to pull the trigger,thanks to all who replied to my questions.(he gives members of the 67-72 chevy truck a discount which helped a lot on keeping the price down)
Old 06-06-2015, 03:18 AM   #7
andrewmp6
Are you going with air bags or coilovers?
Old 06-06-2015, 09:14 AM   #8
68c10airstream
68c10airstream's Avatar
I have noticed that scott's ifs may be one of the few that has the upper a arms that can be lengthened or shortened to perform an alignment. This feature should be paramount to prevent bumposteer because the inner pivot point is not moving during alignment. Read the "make it handle" thread and early on in the thread there are drawings with lines going through the pivot locations affecting bvumpsteer
68c10airstream is offline   Reply With Quote
Old 06-07-2015, 10:46 AM   #9
jerry1194
coilovers
Old 06-08-2015, 06:42 AM   #10
PGSigns
PGSigns's Avatar
Looks like a good way to go.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 06-09-2015, 05:27 PM   #11
dirtyjim
dirtyjim's Avatar
scotts is top notch.
I could be mistaken but I believe fatmans are mustangII based, not that there's anything wrong with that. fatman has been around a long time
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
