Cab corner floor extensions?
Greetings!
Got a question. Used the search button, didn't find anything. Anyway, I've put a new full floor in my 70 C10. The rear of the floor is square on both ends, but as you know, the cab corners are rounded. Is there inside panels that seals the cab? I imagine that will be quite the breeze in the winter time, as well as stuff falling through the floor. Anybody know the answers? Haven't seen any thing like that in any of my catalogues. Thanks |
Re: Cab corner floor extensions?
The very bottom of the cab corner squares off as it folds under and seal to the floor.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
Well, Either I did something wrong, or the reproduction cab corners are off a bit. I'll look tomorrow. Thanks for the quick response.
What brand of cab corner did you get? Where did you buy it from?
Scott |
They are Woodall brand, and I got them from Southern Kentucky classics.
For the Pan and the cab corners to work as stated above, the floor would have had to be below the lower cab belt line. I measured another cab to see where the gas tank bolt holes were from the back of the cab, to the floor, and replicated it on my floor. I think the floor is where it needs to be. |
#6 | |
![]() Join Date: Jul 2010
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
Thanks. Then I guess everything is where it should be.
